I currently have a TS-212-E, bought in June 2014, running 4.3.3.0361, with 2 x 3TB discs under Raid 1 (and an external USB drive for backup). It does the basics (file serving, DLNA, and rsync) adequately, but has never been fast. Recently it seems to be getting slower and slower, taking a 1m30secs to display the logon screen and many of the applications are not responding. (I'm probably running too many apps.)
I am minded to upgrade - probably to a TS-451+ so I can move to Raid 5, explore virtualisation etc. It undoubtedly gets good reviews, and I like the QNAP apps approach in principle - but I can't help be somewhat put off by the issues I've been having. Can I have some reassurance that I'm not making a big mistake?
I am planning to move the discs as is, running (initially) Raid 1, to the 451 which appears to be supported.
Upgrade from TS-212-E
Re: Upgrade from TS-212-E
don't move em over...discussed many many times...
the disks would remain in legacy mode missing all the features of the new lvm disk structure (snapshots etc)
keep the old nas and disks as backup and buy new drives and transfer the data over
Thanks for the response.
Since I have (most of) a backup on the USB drive, I'm minded to adjust my approach, wipe both discs and start again, probably buying one more 3TB disc as a temporary store for the other content.
But I haven't yet heard that moving from the 212-E to a TS-451+ is likely to cure the performance issues - feedback please.
It will definitely be much faster. Though nobody can tell if it's fast enough (whatever that is?) unless you're much more specific about your usage and configuration.dusherwo wrote:But I haven't yet heard that moving from the 212-E to a TS-451+ is likely to cure the performance issues - feedback please.
If you start playing with virtualization, it may become even slower than the old unit...
I had thought that virtualisation would stress the box so wasn't planning to run it all the time - and was also planning to expand the RAM.
What is also, sadly, relevant is that I read this posting on viruses ( viewtopic.php?f=50&t=136085 ) and can see similar issues on my box - some look as if they have been cleaned by the Malware remover. I guess this is impacting performance.
I was able (I believe) to clear the virus and performance did improve - but in the meantime I had ordered a TS-451+. I followed advice, used backups and cleared the discs (+ a third one I ordered) and yes, it is much better.
I have tested out HD Station and it isn't lively but I have the base RAM. I plan to upgrade, probably to the (unsupported) 16gig, retest and try out the Virtualisation and Container Stations - though it's hard to find anything on the latter which would be useful/interesting which isn't available as a QPKG, either proper or from the Qnap Club.
I had an issue with the Proxy station not working and raised a ticket with QNAP. It is now working though I never heard what they did.
