Admin password glitch
I am looking to upgrade my TS 212P but, having had a glitch with the login account/password not being recognised and needing a certain amount of 'surgery' and ssh. I would like to know whether this problem persists with later models such as TS 351? I gather that the problem has been well-known but I could not find anything about its eradication, although the solution posted by PWilson certainly was effective in resolving the problem.
- Don
Re: Admin password glitch
You have not told us about the glitch so unable to respond.
As I said: There was a problem with the login details - Username and Password - not being recognised and therefore no access being given to the HDDs. The solution was to open the case, remove the HDDs and boot up. At this point the default username/password combination was accessible from a webserver. The HDDs were hot-connected and remounted by applying some ssh via the web interface. This has been reported on a number of occasions but it is time-consuming and my question was whether the underlying problem had been resolved in current models. ('Glitch' a technical fault, usually temporary)
cant recall any such issue
you got a link to the discussion/info about it ?
In have a 419p+ and never encountered it
- Don
Same here, don’t recall any such issue.
