Hello all! As you can tell by the subject I am new to the NAS concept.
I have over 8TB in movies and over 2TB in music. I mostly use macOS in my home network. I would like to use NAS to access multimedia (specifically to play movies on the tv) and for backups. Right now I have a whole bunch of external hard drives that I would like to consolidate somehow.
Do you have specific models for macOS?
Can I use NAS for both backup and multimedia simultaneously?
If I purchase a 4-bay model, do all bays need a disc before I can use it?
I would like to purchase directly from Qnap, is that possible?
If not, do you have any recommendations?
Thank you for taking the time. Please forgive my ignorance on this subject!
Beginner!
- OneCD
Re: Beginner!
Hi and welcome to the forum.
Please ensure you purchase compatible drives for your NAS. Good luck!
Nope, all models work the same with macOS.
You sure can, but a low-end, underpowered ARM model might be a bit "glitchy". Choose one with an Intel or AMD CPU instead.fistsergeant wrote: ↑Wed Jan 20, 2021 9:24 am Can I use NAS for both backup and multimedia simultaneously?
No, but you must begin with at-least one drive. You can then add more as-required. More drives gives you redundancy, then higher capacity.fistsergeant wrote: ↑Wed Jan 20, 2021 9:24 am If I purchase a 4-bay model, do all bays need a disc before I can use it?
QNAP don't sell their NAS direct to the public. But there are many QNAP dealers out there you can buy from. There are a few on eBay that can ship almost anywhere.fistsergeant wrote: ↑Wed Jan 20, 2021 9:24 am I would like to purchase directly from Qnap, is that possible?
As you're a mac user, something to be aware of: owning and maintaining a NAS requires a bit of work and a lot of knowledge. It helps if you already know your way around IP networking.fistsergeant wrote: ↑Wed Jan 20, 2021 9:24 am As you can tell by the subject I am new to the NAS concept.
- spile
- Been there, done that
Re: Beginner!
My LAN is not reachable from the internet. I have no ports (other than for Wireguard) forwarding on my router and of course, UPnP is turned off.
Wireguard (running on the RPI) creates a tunnel with a virtual network interface.
Client (phone, tablet, laptop) ------------ Internet ------------------ Router (DDNS* URL -------------- Wireguard VPN Server on RPI
* Instead of using a dynamic DNS provider, I run an updater script on the RPI that keeps my public website CPanel updated.
It has been rock solid in terms of reliability and makes accessing my NAS, security cameras and other LAN devices much easier as well as more secure.
