Hi, I wish to buy the cheapest NAS server with minimum 8 bays of 3.5" with SAS 12g interface, for using it with 8 HDD WD Ultrastar HC550 18TB (WUH721818AL5204 0F38353)
I've found only expensive models like this one:
QNap-tvs-ec1280u-sas-rp-16g-r2-us
5732 U$D on newegg.com https://www.newegg.com/qnap-tvs-ec1280u ... -_-Product
Is there is any other cheaper model?
Is it compatible with 18TB HDD? because on the compatibility list I see up to 16TB.
I actually own 5 NAS TS-832x but they don't support SAS controllers PCI cards
Cheapest NAS with SAS 12g interface
- Toxic17
Re: Cheapest NAS with SAS 12g interface
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
- Easy as a breeze
We don't sell many NAS with SAS drives anymore. Even the TVS-EC1280U-SAS-RP-16G-R2-US is no longer made.
If SAS drives are preferred for performance, our QuTS Hero NAS should have better HDD performance than a normal QTS NAS. So even with SATA drives our Hero NAS should perform well.
I already have 8 x Wd Ultrastar HC550 drives of 18TB each, with SAS interface, which Nas should I buy for them?
thanks but TES-1885u its too expensive for our needs, we run a small audiovisual production house, we only a NAS with at least 8 SAS 12g bays and 10gbit ethernet to integrate it in our network. It's not for "mission critical" application, thanks
there is no cheap SAS NAS .other alternative is to return the drives and buy SATA ones
ok, I cannot return the SAS disks anymore
Is it better to buy TVS-EC1280U-SAS-RP-16G-R2-US or a combination of a new QuTS Hero Nas, a 12G SAS expansion card and a 12G SAS enclosure? which ones do you recommend? thanks
Which system do you think it will perform better for my SAS HDDs??
Old QTS SAS NAS: TVS-EC1280U-SAS-RP-16G-R2-US
or
NEW QuTS SATA NAS: TVS-h1288X-W1250-16G
with a SAS JBOD EXPANSION: QNAP TL-R1220Sep-RP
and a Dual-port External SAS 12Gb/s storage expansion card: QXP-820S-B3408
both systems are near the same price
thanks
or
thanks
