Can i install the hard drives from my failed qnap nas in a tr004 and read the content via my other QNAP NAS ?
I had my old NAS set up a large JBOD, if the TR 004 was also set up ready as jbod would it work ?
View old NAS drive contents in TR 004
- parkerc
- Easy as a breeze
Model Name : QNAP TS-253be (16GB) & TS-453D (16GB)
Firmware Version:: QTS Latest
OS Version : Apple iOS (iPad/Safari Browser)
Number & Type of HDDs : 2 x 3TB WD Reds, Raid 1 & 4 x 4TB WD Reds, Raid 5
Website (When I have time) : http://www.nodecentral.co.uk
Re: View old NAS drive contents in TR 004
No. TR-004 uses a hardware RAID that is completely different from the software RAID in all Qnap NASes. Dont try it as your disks will be overwritten.
Your best option is to get a Qnap that is compatible for migrating the disks over.
