Hi all.
I have a TS-653A and the coastal air is playing havoc with the trays and hinges on my HDD trays. They need replacement - and perhaps I should take better care of them in future! I think that the SP-TS-TRAY-WOLOCK is the right tray for the TS-653A - based on the fact it looks like mine, but I see there is also a plastic model which might do better in this environment, the TRAY-35-NK-BLK03. Are these interchangeable and fit into this NAS? Appreciate your advice. Cheers, Allan
The right trays for the TS-653A - Coastal location
- bigkid
QNAP TS-230 WD 18TB Drives
- bigkid
Re: The right trays for the TS-653A - Coastal location
Heard back from Qnap. The correct ones are the SP-TS-TRAY-WOLOCK.
