Usage of the USB port on QMiro-201W?
Interested in our products? Post your questions here. Let us answer before you buy.
lazymiaomiao
Post by lazymiaomiao »
I'd like to confirm the usage of the USB port on QMiro-201W. Can I plug in a printer thru the USB port and it will become to a network printer? There is no guidance in the UG or website.
dolbyman
Re: Usage of the USB port on QMiro-201W?
Post by dolbyman »
according to the manual, the USB is only for external drives
no print server functionality
lazymiaomiao
@dolbyman, thank you for your prompt reply. May I ask which manual you are referring to? I checked the UG (user guide) but it mentioned nothing. I just want to be sure. Thanks again!
dolbyman
Post by dolbyman »
exactly , the user guide talks about HDD only
the compatibility guide talks about hdd only
you can deduct that there is no printserver
lazymiaomiao
OK, thank you for your guidance @dolbyman.
Return to “Presales”
