Looking to replace a TVS-1282T with something more powerful (CPU)
Interested in our products? Post your questions here. Let us answer before you buy.
cryptochrome
Been there, done that
Post by cryptochrome »
I am generally happy with my TVS-1282T, but the CPU (i7-6600) is getting a bit dated, especially when it comes to hardware encoding capabilities of video files. The i7-6600 does not support h265 hardware decoding and encoding, for example.
What would be a "next-generation" replacement for the TVS-1282T? Something with similar storage room (number of disks, SSDs) but with a more modern CPU?
antik
Know my way around
Re: Looking to replace a TVS-1282T with something more powerful (CPU)
Post by antik »
Replacement instead of TVS-1282T3 is model TVS-h1288X with Xeon W-1250 6-core: https://www.qnap.com/en/product/tvs-h1288x
TVS-h1288X-W1250-128G (850W) + T3 card + QXG-10G1T + GIGABYTE RTX 4080 Super Gaming OC 16G (Silent FW) + 2x 2TB M.2 NVMe Kingston KC3000 (RAID0 - apps, Qsync, VM's) + 12x 2,5“ 3,84TB SATA SSD Kingston DC600M (RAID5 - VM's, data).
TVS-1282T3-i7-48G (450W) + QXG-10G1T + PALiT GeForce GTX 1660 Super GP OC + 2x 1TB M.2 NVMe ADATA SX8200PNP (RAID0 - apps) + 4x 2,5“ 3,84TB SATA SSD Samsung PM883 (RAID5 - data backup) + 8x 8TB Seagate IronWolf Pro (RAID6 - data backup).
TS-677-16GB + 1x 256GB SSD Samsung EVO (apps) + 3x 8TB Seagate Exos (RAID0 - QVR Pro cameras recording)
Network stuff (priority use of 10GbE): QHora-301W, QSW-804-4C, ASUS XG-U2008 and TP-Link TL-SG1008MP. Protected by 2x APC CYBERFORT II 700VA.
cryptochrome
antik wrote: Mon May 17, 2021 5:21 am Replacement instead of TVS-1282T3 is model TVS-h1288X with Xeon W-1250 6-core: https://www.qnap.com/en/product/tvs-h1288x
Thanks. It's running QuTS with ZFS though. I want to be able to just take my disk pack and move it to the new NAS. I suppose I can't do that here since both NAS run different operating systems?
antik
Know my way around
Post by antik »
Exactly. This cannot be done due to differences between QTS (ext4) and QuTS hero (ZFS). So back up the data elsewhere, then move the disks, etc., set up and upload the data to a new NAS.
Or, If you would like to use QTS on the TVS-h1288X, then this can be done with data retention etc. First without disks in Qfinder reinstall firmware on the flash from QuTS hero to classic QTS OS and then put the disks in there etc. and run the NAS and all will work after reboot as the same as it worked in TVS-1282T3.
cryptochrome
Oh, that's good to know that I can switch over to QTS. Thanks.
Return to “Presales”
