Ok so I currently have an old Synology I’m switching from. My current setup consists of a 12TB volume connected to a Mac Mini which is my Plex Server and Homebridge server. I’ve been pricing out an unRAID setup based on some good recommendations I received however that had its own challenges… namely, buying the right components, building it, optimizing it over time for the right balance of power/performance. That got me to thinking about QNAP which has a wider variety of NAS to choose from. What I need is simple:
1.) A rock solid Plex machine that can transcode at least 4 1080P streams at once
2.) At least 6 drive bays but preferably 8
3.) Can run Homebridge docker container
4.) Can download and seed torrents
5.) Can run several other containers I’d need be
Is there a unit like this? I checked out TVS-627x and TVS-827x but they sure are expensive and I’m not convinced about how they would do with Plex performance. I can stomach up to $1300’ish (+/-) if it truly meet all my needs.
Will these units do what I need them to?
Are there cheaper units that would do what I needed? Maybe with GPU upgrade using the pics slots?
I’ve never owned QNAP so I don’t know their capabilities or even how mature or polished their software stack is compared to Synology.
Any guidance would be helpful. Thanks!
Which QNAP would meet my needs?? Help me spend my money.
- Moogle Stiltzkin
Re: Which QNAP would meet my needs?? Help me spend my money.
4 simultaneous streams? live transcoding?
not too sure about that but you can check here
https://support.plex.tv/articles/200375 ... uirements/
https://support.plex.tv/articles/201373 ... lity-list/
more specifically here
https://docs.google.com/spreadsheets/d/ ... 0jdj3tmMPc
if you get an intel celeron model there is the ts-x53d series.
or other options like ryzen or intel i3 etc such as
TS-h973AX
TS-673A
TVS-672X
you can browse here
https://www.qnap.com/en/product/
i just listed the models that i think are good. especially the ts-673a series which has
- ryzen cpu
- quts hero os (this is zfs linux)
- ecc ram support
- other modern connectivity options were added in this series
if you have the budget, i highly recommend you go for the quts hero labelled models (not the very highest one. but something like x73a is good)
a cheaper option than that would be something like the x53d series, but these are on qts os if you don't mind being stuck with ext 4 linux filesystem compared to the newer zfs linux option. also with this series it's an intel cpu so if you have a plex pass you can do the intel quick sync will that be enuff for your 4 streams requirements? i don't know that. i usually just do 1 streams at a time for live transcodes
you can check rob's channel he did some plex transcode tests
QNAP TS-873A NAS Plex Tests - 4K & 1080p
https://www.youtube.com/watch?v=fA3wGOA4Ss4
if you're not familiar with qnap maybe this will help
How to Configure Plex on your QNAP NAS running QuTS Hero
https://www.youtube.com/watch?v=FbjQbkDsAAU
to install plex on your qnap, you do it from appcenter. You go to the official plex site, download the qpkg file, then install on your qnap. easy.
other option is to setup qnap container station, then install the plex docker app.
there is also an alternative to plex which is kodi. kodi can be downloaded from here and is actively maintained. or also via container station (docker)
https://qnapclub.eu/en
TS-h973AX
TS-673A
TVS-672X
you can browse here
- ryzen cpu
- ecc ram support
refer to plex requirements, the google sheet and also robs plex testing videos. or maybe someone else will come along to tell you1.) A rock solid Plex machine that can transcode at least 4 1080P streams at once
the series mentioned has that many bays. cept the x53d series which is up to 6bays if not mistaken?2.) At least 6 drive bays but preferably 8
yes no problem. as for the torrent you can either use a torrent qpkg or go install a torrent client docker app of your choice.3.) Can run Homebridge docker container
NAS
Network
Resources
Network
Resources
Thanks so much for the detailed response! Any idea where else I can see this list? The link is giving me an access denied. I think they had too many views on the document for a single account or something.Moogle Stiltzkin wrote: ↑Tue May 18, 2021 9:11 am
I'm really torn between an AMD mode or intel one... With intel, I can use QS for hardware accelerated transcoding... with the AMD I'd have to get a separate GPU which I'm ok with however how do I know which GPU's work with a QNAP and how stable a QNAP is with a GPU?
- Moogle Stiltzkin
tbh i don't know either. it was working not too long ago, not sure what changed. you might be able to find more about it on the plex forum since i believe they are maintaining that list.itpromike@gmail.com wrote: ↑Tue May 18, 2021 11:06 am
with an intel cpu, you can use quicksync for plex. but that requires a plex pass in order to use.itpromike@gmail.com wrote: ↑Tue May 18, 2021 11:06 am I'm really torn between an AMD mode or intel one... With intel, I can use QS for hardware accelerated transcoding... with the AMD I'd have to get a separate GPU which I'm ok with however how do I know which GPU's work with a QNAP and how stable a QNAP is with a GPU?
for an amd cpu, if the cpu is good enuff, you can do software x264 transcoding and it will be fine.
or if not, the other option is to install the nvidia graphics card (in a nas model that supports it), then use plex video card transcoding (requires a plex pass as well)
NAS
Network
Resources
Network
Resources
- jaysona
- Been there, done that
1080p is meaningless, what is improtant is the codec and bit depth. Are you transcoding AVC or HEVC, 8-bit or 10-bit? Is it 1080p -> 1080p or 1080p -> 720p transcodig, etc, etc, etc?itpromike@gmail.com wrote: ↑Tue May 18, 2021 8:37 am ...
How many running at the same time? How much memory and CPU resources will be consumed with the docker and containers?2.) At least 6 drive bays but preferably 8
There are plenty of units that meet the technical requirements, but not at the price point you are willing to pay.Is there a unit like this? I checked out TVS-627x and TVS-827x but they sure are expensive and I’m not convinced about how they would do with Plex performance. I can stomach up to $1300’ish (+/-) if it truly meet all my needs.
The only unit I can think of that will meet your price point is the TS-653d with 8Giug RAM. It has a Gemini Lake based CPU which means hardware transcoding for all the commonly used codecs for the torrents you'll be downloading. 8Gig of RAM is a bit on the low side for the all the dockers and containers, but it will be usable, performance won't be stellar, but it will work.
Forget about any AMD CPU for use with plex where transcoding is involved.
RAID is not a Back-up!
H/W: TS-219 Pro / TS-509 Pro
Thanks for the reply here is the additional context that might be helpful...jaysona wrote: ↑Wed May 19, 2021 12:47 am1080p is meaningless, what is improtant is the codec and bit depth. Are you transcoding AVC or HEVC, 8-bit or 10-bit? Is it 1080p -> 1080p or 1080p -> 720p transcodig, etc, etc, etc?itpromike@gmail.com wrote: ↑Tue May 18, 2021 8:37 am ...
1.) 1080P mkv files that are MOSTLY 8bit. There could be a 10bit file here or there. It would transcode to 720 at the lowest. Also all the streaming device that would be connected are Apple devices
2.) The most important things are simultaneous Plex streaming and the Homebridge container... anything else is extra for fun
3.) The price point is $1300 not including drives - just the unit itself. I'm willing to do only 6 drives to have more money for RAM upgrades or even just schedule out RAM upgrades over the next months.
4.) I'm also open to a model which doesn't do hardware transcoding but I can add a discrete GPU in a couple months.
Thanks!!!!
- jaysona
The TS-653D is the only unit I can think of that is within your price range and ticks off the boxes. You'll have a few dollars left over for RAM upgrades or bigger hard drives.
Stick with the Intel CPU and Quicksync, forget AMD and GPUs for plex and your price range, plus with the GPU, h/w transcoding capability is at the convenience of NVIDIA and their fickle support of Linux, one day NVIDIA may decide to once again limit the number of h/w transocde streams or remove Linux support all together.
