QUTS Hero support TVS-672N
Does the TVS-672N support Quts Hero? I’m about to purchase one but wanted to know before I purchased. Thank you
- rafale
- Easy as a breeze
Re: QUTS Hero support TVS-672N
Nope, It's been extensively discussed in other threads. It requires a license which can't be bought. Not sure if it ever will.
Server: TVS-872XT i9 9900 ES, 64GB DDR4 2666MHz, intel X550-T2, Asus RTX3070 Dual OC (On pico PSU), 2x Phison E12 1TB M.2, 4x Micron 5210 7.68TB, 4x WD Purple 4TB
Backup NAS: TS-473 20GB DDR4 2400MHz, Mellanox ConnectX3, 2x Samsung PM871b 256GB M.2, 4x WD Red 8TB
Former units: TVS-1282, TS-871, TS-469
- rafale
- Easy as a breeze
At this moment, that is correct. They are generally Xeon based platforms with ECC memory support and horribly overpriced. There has been a plan to offer QuTS hero to other higher end platforms like the x72s and actually the firmware has even been published but it doesn't allow anyone to try it due to the lack of a license key. I really like(ed) the x72 platform until the large amount of report of sudden motherboard deaths to which QNAP has not responded at all and made people discover how horribly impractical their warranty service is and let alone people who have out of warranty units and are SOL.itpromike@gmail.com wrote: ↑Wed May 26, 2021 9:00 pmSo the only ones that run QUTS hero the “Quts Hero Editions” and that’s it?
#TVS-682, i7-7700T, 64GB, QM2-2P10G1T, SFP+ 10Gbps, #TVS-673, amd r-series 4-core, 64GB, SFP+ 10Gbps, #TVS-473, amd r-series 4-core, 64GB, SFP+ 10Gbps
Updating the 672n to QUTS version stops and fails at 42%.
Was the NAS completly erased first..?
I dont think you get go from QTS to QuTS with a simple update (hence it failed)
Ahh... yes... reinitializing followed by quts update did it.
bancha
bancha
