I just purchased a TVS-872X. I want to buy two 1TB M.2 SSD to use for First Storage Pool (QuTS OS, apps, VM). The specs say I require M.2 2280 PCIe Gen3 x2; however, almost all of the SSDs listed on the compatibility list are for Gen3 x4 and no 1TB listed for Gen3 x2.
I'm new to this, so am I misunderstanding something?
TVS-872X M.2 SSD Compatibility list doesn't seem to align with specs??
[Main Server]
QNAP TS-872X7 (QuTS)
PCIe Gen3 x4: QNAP QM2-2P-344 with 2 x 2TB XPG SX8200 Pro NVMe
8 x WD102KFBX 10TB Red Pro, RAID6
[Backup]
TS-128A
18TB WD181KFGX Red Pro
[Backup]
TS-128A
Re: TVS-872X M.2 SSD Compatibility list doesn't seem to align with specs??
k thanks for your reply.
Are there any guidelines on how to find/select the 1TB M.2 2280 PCIe Gen3 x2?
[Main Server]
[Backup]
TS-128A
[Backup]
TS-128A
Gen3 x4 lane SSDs should work with Gen3 x2 lanes, it will just halve the bandwidth. In real world use, it won't make a significant difference. I currently have 2 x ADATA XPG SX8200 Pro 1.0TB in my TVS-672N and it works without issues.
TVS-672N h5.0.1.2248 build 20221215
i7-8700T | 64GB DDR4 (2 x M471A4G43MB1-CTD) | 2 x Samsung 970 Evo Plus 1.0TB | 6 x 18TB HGST HC550
K thanks. I ended up getting the same model (but 2 x 2TB).
I decided I didn't want to lose half the bandwidth and ordered the QM2-2P-344. QNAP support confirmed QuTS supported it for boot, but they were mistaken (they remote connected and confirmed that there's a problem with QuTS supporting it right now).
[Main Server]
[Backup]
TS-128A
[Backup]
TS-128A
I have a QM2-2P-384 with the 2 x 1.0TB ADATA SSDs and I was able to install the system pool on it. When I check the system pool I see apps on it and can migrate other apps on the HDD pool to SSD system pool on the QM2 card.
I was able to do the same - it worked fine until I restarted the NAS.
Curious if you are using QuTS or QTS? Maybe didn't affect QM2-2P-384?
QNAP updated my ticket and confirmed they resolved the problem:
The issue has been confirmed to be patched on FW h4.5.4.1758 build 20210812.
[Main Server]
[Backup]
TS-128A
[Backup]
TS-128A
I assume (hope) that this is the fix for QM2-2P-344:
Release Notes:
QuTS hero h4.5.4.1771 Build 20210825
- After users restarted the NAS, QuTS hero would unmount storage pools that were created with SSDs installed on the QM2-4P-384 expansion card.
Release Notes:
[Main Server]
[Backup]
TS-128A
[Backup]
TS-128A
