I'm looking to upgrade from my old 869-Pro to the TS-873A. I'm trying to spec the hardware buy, but have a couple of questions. The primary use for the device is file services (backup storage, media storage for Plex, possibly host a Plex server and do transcodes on 1080p streams (only 1-2 streams concurrently probably).
Is a 873A overkill for such a use?
If I were to go with QuTS Hero - so I really need the SSDs for the file system metadata etc? Is there a significant penalty for running the system pool as HDD particularly in a home environment?
If I need the SSDs, how big? 256 or 512 GB?
Sorry if these are FAQs, didn't find these answers... If there's a reference, please let me know. Thanks.
'-Alan
Upgrading to TS-873A - SSD
- Easy as a breeze
Re: Upgrading to TS-873A - SSD
There is a penalty for running the system pool on HDDs. Even for home use. But if the system pool is SSDs, you can also put your apps on the system pool so Plex and other apps run better. If you have SSDs for your apps to run on, I think it also makes sense to run the system on those SSDs as well.
thanks for the response. Is there any articles or tech notes that could help me quantify the penalty if I didn't pop for the SSDs, whichever size I need? Is the penalty worse that just going QTS instead of Quts?
- Easy as a breeze
I don't have an article that says exactly how much the penalty is. But if you don't have an SSD pool for your OS, then I expect this to perform worse than QTS.
