Hello all,
I have two internet connections, one via ethernet and one via WiFi.
I want qnap use the main internet connection via ethernet.
Also to I want to create a virtual machine and use the WiFi connection at this machine.
Is it possible?
ts-253d + virtual machine + 2 internet connections
Re: ts-253d + virtual machine + 2 internet connections
Sure..connect the wifi via wifi bridge (also connects via lan) and connect the other via plain lan
Thank you @dolbyman for your reply.
I have another question...
My two internet connections are slow. I'm downloading with 1.5 Mb/sec.
I m taking daily backups from a European web server.
I want to use ethernet internet connection and WiFi ( via WiFi bridge) connection to get my backups.
Shall i have virtual machine to do this from qnap?
How can i use the two ethernet ports?
I shall set two IPs at my qnap and i will send from my web server, half of backup files at 1st IP and the others at 2nd IP.
without knowing the exact setup and what is done, I cannot give any tips
best hint..try it
best hint..try it
