TS-451 memory upgrade (compatibility)
What mem-modules are suitable with TS-451?
Eg.
Can Kingston HyperX Impact SODIMM - 8GB Kit* (2x4GB) - DDR3L 1600MHz
Part Number: HX316LS9IBK2/8
Specs: DDR3L, 1600MHz, Non-ECC, CL9, 1.35V, Unbuffered
be used?
Eg.
be used?
- schumaku
Re: TS-451 memory upgrade (compatibility)
Known working DRAM for TS-x51 are:
Kingston KVR16LS11/4 (4GB PC3L 12800 CL11 204 pin SO-DIMM) - single or in a pair
CRUCIAL CT51264BF160B 4 GB SO-DIMM DDR3L (1.35 V) PC3-12800 (1600 Mhz) CL11 - single or in a pair
Note the TS-x51 requires pairs of similar SO-DIMM modules when using both slots.
Most likely yes - 1Rx8, based on eight 512M x 8-bit FBGA - so a similar layout as the KVR16LS11/4, don't know if the lower 9-9-9 latency timing does bring a reasonable advantage.vakavanha wrote:Kingston HyperX Impact SODIMM - 8GB Kit* (2x4GB) - DDR3L 1600MHz
Two questions:
1) Any reason to get a single 8gb module vs. two 4gb modules?
2) What is the maximum speed? According to http://files.qnap.com/news/pressresourc ... 608-RS.pdf it is 1333, but the QNAP replacement http://shop.qnap.com/index.php?route=pr ... uct_id=131 is a single 1600 module.
- schumaku
Using both channels is commonly agreed to be faster, optimal is equipping both SO-DIMM with the same sized modules.8bitkid wrote:1) Any reason to get a single 8gb module vs. two 4gb modules?
As per Inhell Ark for the J1900 CPU -> DDR3L-13338bitkid wrote:2) What is the maximum speed?
The PC3-12800 (1600 Mhz) modules are easier to find, more main stream (as used for performant notebook computers), and the price might be lower than for pure PC3-10600 1333 MHz DDR3 SO-DIMM modules.8bitkid wrote:..., but the QNAP replacement ... is a single 1600 module.
Some ultra clever geeks might find modded boards built and/or optimized to different specs.
-Kurt.
32-bit VAX kid, 64-bit Alpha kid
Got it, thanks so much!
So based on the review here: http://geeklingo.net/qnap-ts-451-review ... d04aca500/
Are these modules probably the way to go? http://www.amazon.com/dp/B004GV0IOW/ref ... 00_TE_item
- schumaku
No, most likely not - can't see a reference for being a PC3L / DDR3L / 1.35V version.8bitkid wrote:Are these modules probably the way to go?
The Corsair Value RAM the GeekLingo tried to install can't work because these are not a low voltage 1.35 V SO-DIMM, too.
Got it, thanks so much.
So, it seems like this would work: http://www.adata.com/index.php?action=p ... 227&lan=en. I know it is 1600...is that okay?
However, I can't find it on Amazon, so if I want 8gb, it seems like this is the way to go? http://www.amazon.com/Crucial-PC3-12800 ... B008LTBITY
But, to play it safe, I've ordered two of these: http://www.amazon.com/gp/product/B00CQ3 ... PDKIKX0DER
I used, ManufacturerPartNumber: CMSO8GX3M2C1600C11, Corsair Value Select 8GB (2KIT) SO-DIMM DDR3 1600MHz CL11 and it works perfectly.
- schumaku
8GB DDR3L SODIMM Memory Kit (CMSO8GX3M2C1600C11)conney wrote:I used, ManufacturerPartNumber: CMSO8GX3M2C1600C11, Corsair Value Select 8GB (2KIT) SO-DIMM DDR3 1600MHz CL11 and it works perfectly.
I have built in 1x Crucial 8GB DDR3 1600 SODIMM 1.35v a few weeks ago. Works fine.
Here installed is 2x4 GB, Corsair Value Select CMSO8GX3MC1600C11. Works flawlessly.
Hi all,
what is maximum amount of RAM to be mounted? 2x8 Gb. or 2x4 Gb. ?
Thanks in advance
Maurizio
Thanks in advance
Maurizio
I used 2xCT102464BF160B Crucial........ohhhh yeahh 2x8GB RAM module, 16GB total.
All works fine! System recognize the 16GB and also the NAS and the virtualization station.
Regards
Alessio
Regards
Alessio
I have read all of the reviews posted and also talked to the pre sale tech support and still can not get a straight answer
I would like to upgrade the TS-451 to 8GB of RAM (4GB x2 Modules)
Can someone please give me a link to a store to purchase modules that are compatible with the TS-451.
THANKS
THANKS
- schumaku
Hello Chris,
Regards,
-Kurt.
How unlikely - the official supported modules are available direct from QNAP - high costs due to shipping&handling from Taiwan. -> http://shop.qnap.com/index.php?route=pr ... uct_id=129chrismcastillorn wrote:I have read all of the reviews posted and also talked to the pre sale tech support and still can not get a straight answer
Yes, this makes a supported config.chrismcastillorn wrote:I would like to upgrade the TS-451 to 8GB of RAM (4GB x2 Modules)
Why ask so specific for "A shop" - depending on your market, I would assume it should be possible to find the Kingston or Crucial modules discussed in this (and similar) threads on TS-x51/TS-x53/TS-x53S Series. Where are you located?chrismcastillorn wrote:Can someone please give me a link to a store to purchase modules that are compatible with the TS-451.
Regards,
-Kurt.
