Hi
I just installed VyprVPN 0.9.0 on my TS-559 Pro II (4.2.2(20160823)) NAS. I used the QNAP Store on my NAS to install the application, and it installed without errors, but when I try to open the application (https://192.168.1.170:7515) I get a browser (IE,Chrome,Firefox) error indicating that the page can't be reached/displayed.
Are there some other settings I need to set manually to complete the install?
Take care,
Shayne
VyprVPN 0.9.0
Re: VyprVPN 0.9.0
Same problem here. It seems that some script have such hard-coded paths in it, that it can't find Python3...
I have no solution... I would raise a ticket at QNap.
- Daneel89
Re: VyprVPN 0.9.0
Same problem too
_____
QNAP TS-459 Pro (4.2.2 Build 20160901-2016.09.01)
» Files Server & Download Station
- Volume RAID 6: 4x 1GB EXT4 formatted (Hitachi HDT721010SLA360 ST60)
- QPKG Plugins: Transmission 2.84-b24 (14160)
Synology DS-106e (DSM 2.0 Build 0731-2009.01.13)
» MultiMedia UPnP DNLA Server
- Volume: 1x 1GB (Samsung HD103UI)
DVICO TViX M-4000P (Firmware 2.2.7 (PAL, French)-2008.02.23)
» MultiMedia HDD & MultiMedia DMA GateWay
- Volume: 1x 500 MB
- Volume: 1x 500 MB
Re: VyprVPN 0.9.0
I just got it to work.
Simply, install it manually using these instructions (easy) and it works very well
viewtopic.php?f=231&t=125551&p=566644&h ... pn#p566644
Re: VyprVPN 0.9.0
192.168.0.244:12201 uses an invalid security certificate. The certificate is not trusted because it was signed by the exhibitor. The certificate does not apply to the name 192.168.0.244. Error Code: SEC_ERROR_UNKNOWN_ISSUER
any help are welcome
Re: VyprVPN 0.9.0
Has anybody had any luck with finding the solution to this?
Have been on the Vypr/GoldenFrog Live Chat and the person there was stumped as well.
They've escalated it and have submitted a ticket with Qnap.
Re: VyprVPN 0.9.0
Did someone found a solution ? Same problem here
With all version 1.0, 1.2, 2.0...
Re: VyprVPN 0.9.0
In the interface of your router (or internet box), open 7515 to your NAS ip
I had the same problem but now it's ok
Re: VyprVPN 0.9.0
Like all the thousands that exist, this port must be open.skypx wrote:So now every bot, black hat and internet baddie can access port 7515? Cool.... good luck.Hurricane-44 wrote:In the interface of your router (or internet box), open 7515 to your NAS ip
Like any web server or application that would use specific ports.
Please verify your firewall to see all exceptions you have.
Security can be managed elsewhere and / or adjusted.
But it's easy to criticize a solution rather than give a concrete one
Surely you have found a way to run your VyprVPN without opening it ?
Oh, for every bot, black hat and internet baddie you can close 443 or 80 too
