Remove QTS SSL Certificate app in 4.3.2?
- mikolajek
I've been using 32-bit firmware for quite a while and always removed the QTS SSL Certificate app, since I'm not using QNAP commercial ceritifcates. When I upgrade to 4.3.2 beta I noticed that I can't remove it any longer - when clicking on the drop-down arrow of this app, nothing happens. Is this a bug or has this simply been limited in this firmware version?
Re: Remove QTS SSL Certificate app in 4.3.2?
I have seen this on my beta equipped NAS.
Can't explain why though.
Primary: QNAP TS-h1283XU-RP w/ 10 x Seagate EXOS 16TB in RAID-TP
FW QuTS Hero H5.0.0.1949 / 32 GB ECC RAM / Built-in 10 Gig network
Backup #1: Synology RS3617XS+ w/ 10 x Hitachi Ultrastar 10TB in RAID 6
FW DSM 7.0.1-42218 Update 3 1 / 8 GB ECC RAM / Built-in 10 Gig network
Backup #2: QNAP TVS-863 w/ 8 x Hitachi Deskstar 6TB in RAID 6
FW 5.0.0 / 8 GB RAM / LAN-10G2T-X550
Ternary: 2 x QNAP TS-879U-RP w/ 8 x WDC Red 4TB in RAID 6
FW 4.3.6 / 32 GB ECC RAM /
Ternary: QNAP TS-470 Pro w/ 4 x WDC Red 4TB in RAID 6
FW 4.3.6 / 16 GB ECC RAM /
I had the same problem.
You must connect to your NAS in SSh and enter the following command :
setcfg QcloudSSLCertificate Sys_App 0 -f /etc/config/qpkg.conf
Now you can remove the app.
- mikolajek
Worked perfectly! Many thanks for this tip!
- whoisnader
Thanks for this. I had reverted back to 4.2 after testing 4.3.2 and the SSL app was nolonger compatible (as I had to upgraded the app when I installed the beta) compatible. I had to remove the new version using this to be able to install the older version.
Tip works for my NAS with QTS 4.3.3 build 136.
However, when I reboot it is back again.
Somehow it appears to be reinstalled.
QNAP TS-639pro RAID 6 WD2002FYPS's
QNAP TS-831xu RAID 5 4x 8TB 2x SSD
the same happened hereQPeter wrote:Tip works for my NAS with QTS 4.3.3 build 136.
and after reboot, I can't remove it again.
This works, but only until next boot when the application gets installed again...Calmeraie wrote:Hello,
experience with administration of UN*X (mostly linux) and applications on internet servers since 1994...
- aethling
This situation is unacceptable!
QNAP - please let us remove this application! I do not accept you have the right to foist this on your users! WE HAVE PURCHASED THE BOX, IT IS NOT YOUR PLAYTHING.
- TheRooster2000
- Easy as a breeze
+1!
Mediacenter => QNAP TVS-1282-i5-16G // 16GB RAM // QTS 4.5.4.2467 // 2x WD red SSD 1TB // RAID1 // 8x WD140EFFX red // RAID5
Backupcenter 01 => QNAP TS-869 Pro // 3GB RAM // QTS 4.3.4.2451 // 8x WD80EFZX red // RAID5
Backupcenter 02 => QNAP TS-869L // 3GB RAM // QTS 4.3.4.2451 // 8x WD80EFZX red // RAID5
QNAP, I want to remove QTS SSL Certificate app. This is unacceptable, that you foist this!
anyone from qnap to please kindly jump in?
I have the same request - be able to completely remove "QTS SSL Certificate".
Thanks,
danausGR
Thanks,
danausGR
open a ticket with qnap ... they do not read here
- OneCD
If even Microsoft (who are usually the last to do anything) are now doing this, why isn't QNAP?Microsoft wrote:Uninstalled in-box apps no longer automatically reinstall
Starting with Windows 10, version 1703, in-box apps that were uninstalled by the user won't automatically reinstall as part of the feature update installation process.
