I would like to uninstall the Ubuntu Kylin add-on from Linux Station, how can that be done?
Thanks!
TS-251+
QTS Beta 4.3.2.0050 build 20170104
[Linux Station] How do I uninstall Ubuntu Kylin add-on?
- DDGNY
TS-251+: 8GB, 2x6TB WD Red RAID1, Pawtec USB DVD-RW
TR-004: 4x4TB WD Red RAID5
UPS: APC Back-UPS ES 750
- ouija
Re: [Linux Station] How do I uninstall Ubuntu Kylin add-on?
Only way I've found to completly "remove" the entry from Linux Station is to uninstall Linux Station and Re-install it. Otherwise you can only disable the containers.
