I am new into this world, I have installed apps from Qnapclub Store repository, which seems to have the latest versions of all apps I require. but now can't open any apps and getting this message "This site can’t be reached"
I have also tried downloading those qpkg but still same luck. I have QNAP TS-251A. and trying to use Sonarr. QNZBGet is working perfectly but I can't open Sonarr, Sickbeard, sickRAge, CouchPotato.
Appreciate your help guys, I am new at this and hoping to find a simple solution.
HELP REQUIRED, Sonarr and other apps showing "This site can’t be reached"
Re: HELP REQUIRED, Sonarr and other apps showing "This site can’t be reached"
Firmware version: 4.3.3.0095
QNZBGet: 18.0.0 (working)
Qmono: 4.6.2.7
QSonarr: 2.0.0.4389
QCouchPotato: 160822
Qmono: 4.6.2.7
QSonarr: 2.0.0.4389
I have the same problem, since the last update of Sonarr I cannot reach it anymore, I guess it's linked to that.
- Trexx
As has been said in many threads, if you are on 4.3.x firmware you MUST MANUALLY install the x64 (64-bit) version of apps.
You CANNOT install them from the qnapclub repository in app center. It will install the wrong version (x86).
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I Have the same problem the i tried the x64 file but all i get is 127.0.0.1 localhost Wrong architecture: Qmono 4.4.2.11 is built for x86_64
