Not sure if this is correct location for this discussion. In regards to using OceanKTV Karaoke app. Im looking to buy a cheaper alternative of the OceanKTV Audio Box. What about these?
Or another option (since technically this would avoid the need for an audio card) I was thinking of is splitting the 1/8 audio cable that goes from my projector to my speakers. My speakers will then get 2 inputs into its audio input. 1) QNAP/OceanKTV & 2) my wireless mics. What do y'all think/ Anybody got theirs setup? Dis a search and couldn't find any conversations about this.... thanks in advance...
Possible Alternatives
1) split audio cord and plug mics directly into speaker
2) buy a cheaper audio box
a) https://smile.amazon.com/Behringer-UM2- ... B00EK1OTZC
b) https://smile.amazon.com/Lexicon-2-Chan ... B000HVXMNE
OceanKTV Audio Box
https://www.qnap.com/en/news/2016/qnap- ... nas-models
https://www.qnap.com/solution/ocean-ktv/en/
http://shop.qnap.com/index.php?route=pr ... uct_id=173
https://www.amazon.com/QNAP-Accessory-K ... B01K1JW1D8
OceanKTV Audio Box - Cheap Alternatives?
- mydjtl
TS-251+
(2) Seagate IronWolf 12TB 7200 RPM 256MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drives
8gb RAM in one slot. 4.3.3
Firmware as of 3/8/2020: 4.4.1.1216 (2/14/2020)
Re: OceanKTV Audio Box - Cheap Alternatives?
Most people outside of asia are not "into" Karaoke much
but I think there is a certain USB soundcard built into that box, without that the Karaoke App might not run ... try it out and see
