Hi All,
I am running a TVS-471 with firmware version 4.2.4.
I am about to upgrade the firmware (to 4.3.3.0210) but before doing so it is recommended that I run the CF64 App to check the compatibility of the Apps that are installed on my NAS.
Installation of the CF64 App has gone smoothly, however when I run the App I see the message 'MYNAS refushed to connect'. I am operating behind a firewall and have my proxy settings set appropriately.
My expectation is that the CF64 App is using a non-standard port, and that my firewall is blocking this App.
Does anybody know which port this App is trying to communicate on?
Alternatively is there a list of known App issues?
Any help will be greatly appreciated.
Kind Regards,
Davo
Attempting to run CF64 App in order to determine potential firmware update issues?
Re: Attempting to run CF64 App in order to determine potential firmware update issues?
Hi there,
same problem, same question with QNAP TS-221.
Any help appreciated, cheers
H.
H.
I just get blank window when I open up CF64 app.
PC: Intel i7 930 2.8 GHz, 12 GB RAM, 120 SSD HDD
NAS: TS-451+, 16 GB RAM, Firmware: 4.3.3.0262 build 20170727
Router: D-Link DIR-655
Bloody CF64 App; about as useful as tits on a bull! LOL
I'm running 4.3.3.0361 and I'm trying to run the CF64 app but I also have the white window.
Can anyone advise please ?. I don't want to apply the update without understanding what apps are impacted. I'm new to QNAP and I'm in the process of setting up my NAS.
System: QNAP TS-453A (8GB)
Drive config: 12TB (4 x 3TB WD RED) - RAID 5
Backup: Seagate 8 TB Backup Plus Hub (3.5" external, USB 3.0)
UPS: APC Back-UPS BX - 700VA, BX700U-GR (AVR, 4 Schuko outputs, USB)
- Trexx
You needed to run the app BEFORE you upgraded to 4.3.x.
Since you are already on 4.3.x release, there is no need to run the app. Upgrade to the latest QTS release via normal mechanisms.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
I got the white/blank window before upgrading, after restarting before upgrading, etc... never got it work.
