Problems with QVPN
Discussion about various official QPKG software applications. Login required to view the contents.
Locked
FrankChutsky
Problems with QVPN
Post by FrankChutsky »
It has bee suggested that perhaps relying on myqnapcloud for remote access is not such a good idea...better I should use VPN. So, that's what I tried: I downloaded QVPN 2.2.655 on my TS-451 running QTS 4.4.1.1064. As soon as I fired it up, I got the following informative message:
I looked in Control Panel --> Network and Virtual Switch and saw nothing about VPN or OpenVPN...I searched throughout the documentation for a hint as to what that message meant or how to address the problem. Anyhow, both "Confirm" and "Cancel" options on QVPN appear do the same thing: Allow me to set up a local VPN server to allow me to do more secure remote access. I tried to set up PPTP:
When I clicked apply, I got the helpful message:
Clearly I am missing something - I suspect that the two error messages are not unrelated. Any help would be greatly appreciated...
FrankChutsky
Re: Problems with QVPN
OK, I solved the above problem: I had to ENABLE OpenVPN, then change to inteface to ALL and change the the second digit of the VPN IP Client pool. Then Apply, then disable OpenVPN and Apply and that took care of the first error message. The second error message was eliminated by changing the second digit of the VPN IP Client pool to a different value. Horray!! No errors!
03045
Post by 03045 »
I had the same problem. As long as I had QVPN Service 2 app open, the dialog box would pop up telling me that “The interfaces used by the following VPN servers are not available.” This was despite the fact that I had neither of the listed VPN servers Enabled. No matter how many times I answered by clicking either Confirm or Cancel, the dialog box would go away, but then return a few minutes later.
Your solution fixed it for me as well. Thanks for sharing!
matday
Post by matday »
FrankChutsky wrote: Mon Sep 30, 2019 11:52 pm OK, I solved the above problem: I had to ENABLE OpenVPN, then change to inteface to ALL and change the the second digit of the VPN IP Client pool. Then Apply, then disable OpenVPN and Apply and that took care of the first error message. The second error message was eliminated by changing the second digit of the VPN IP Client pool to a different value. Horray!! No errors!
This was driving me nuts and nothing i'd tried would get rid of that stupid message 'The interfaces used by the following VPN servers are not available.' everytime i went into QnapVPN it was really annoying!
Thanks for sharing your solution Frank! :-)
EDIflyer
Post by EDIflyer »
THANK YOU!! This was driving me nuts :lol:
OneCD
Post by OneCD »
* this topic has been solved - thank you to everyone for your "thank you"s. :) *
Locked
Return to “Official Apps”
