QVPN - Application not working properly
Discussion about various official QPKG software applications. Login required to view the contents.
flinomartins
Getting the hang of things
Post by flinomartins » Fri Feb 12, 2021 12:09 am
Since upgrading to v2 that I'm having a lot of problems with QVPN.
Even reinstalling and reconfiguring is giving problems and error such as the ones attached.
Even after a reinstall, the option to choose interface has disappeared.
Any had this sort of problems?
Is there a workaround or solution
Thanks is advance
flinomartins
Re: QVPN - Application not working properly
Post by flinomartins » Fri Feb 12, 2021 3:19 am
By the way, does anyone knows the direct link to download:
QVPN 2.2.661 - ( 2020/01/15 )
Return to “Official Apps”
