QuFirewall clogged up!
Hello. Yesterday afternoon, my TS-431 invited me to update the QuFirewall module to version 1.2.0. Everything happened as normal. But since the update, any attempt to open the QuFirewall interface results in a ‘loading’ flag with a working spinner that never goes away –
No part of the QuFirewall interface is accessible other than the top right close/maximize/minimize buttons. The firewall seems fully operational as it stands but no changes can be made. I have been through a reboot or two but there does appear to be a bug in the front end of this module.
Suggestions please.
Suggestions please.
- DDGNY
Re: QuFirewall clogged up!
Exact same thing happening here on ts-251+. The vague Fixes mentioned in the Release Notes aren't that helpful either:
QuFirewall v1.2.0
( 2021/02/24 )
[New Features]
- Added support for IPv6 standard.
- Supports GeoIP database updates to improve geolocation accuracy.
- Added online tutorial to the QNAP Support page.
[Fixed Issues]
- Modified user interface strings to improve usability.
- Fixed some minor issues.
TS-251+: 8GB, 2x6TB WD Red RAID1, Pawtec USB DVD-RW
TR-004: 4x4TB WD Red RAID5
UPS: APC Back-UPS ES 750
OK thanks. The fact that someone else reports an identical issue means that it's probably a simple bug that should not have escaped the software factory.
Doesn't someone test these things before release? As far as your list of "fixes" goes, this seems to be a new issue that arrived with 1.2.0 that they released yesterday. The previous version was fine.
Same on my TS-253D, v1 was fine only started happening after upgrade to v1.2.0. Tried restarting, then uninstall / reinstall but issue persists.
Should this be reported through some official route for bugs, or will it be picked-up from here?
Support ticket created.
- Moogle Stiltzkin
same here. loading but never quite finishes loading ever...
i tried a few things, close, open new browser. close appcenter, reopen.
but still the same :X not sure whats going on.
NAS
Network
Resources
Network
Resources
Same here, TS-251+
Works great here on my TVS-472XT. Brings iPV6 and GeoIP management as a novelty.
Qnap TVS-472XT 32GB | NIC QXG-10G2SF-CX4 | 3 HDD Seagate 6TB | 2 SSD NVMe Samsung 970 Evo 1TB | Drive QDA-A2MAR | 2 SSD Samsung 860 Evo 500GB
Same issue. removed app. reinstalled app. tried basic instead of local. nothing fixes the qufirewall stuck loading bug.
HELP!!
HELP!!
- Don
Open a ticket with QNAP.OnlineUser wrote: ↑Sat Feb 27, 2021 9:19 am Same issue. removed app. reinstalled app. tried basic instead of local. nothing fixes the qufirewall stuck loading bug.
HELP!!
I had the same thing; turned off uBlock Origin extension on my Firefox browser, and the issue disappeared. Got anything blocking your end?
@banimeuk5 - Yes! That solved the problem except I wasn't using a plug in, I merely use Brave (Chrome) browser and
it has auto blocked a 'tracker cookie' causing the loading bug.
Disabling uBlock Origin worked for me too - thanks.
Excellent spot, well done.
UBlock Origin is so smooth that one easily forgets it is running.
