Hi!
I have an old TS-212P with the "latest" QTS 4.3.3 firmware installed and all the apps updated.
Since Clam AV database isn't updating automatically, I'd like to know if I can download the latest version directly from Clam website and manually update the software (not the virus database) myself.
This might sound silly, but I'm not a Linux user and don't know how to do it without some "step by step" instructions.
I'm considering a hardware upgrade for some time, but I'm from Brazil and the currency conversion plus import taxes make it impossible now.
Thank you all!
TS-212P QTS 4.3.3 Clam AV software manual update
Carlos Molina
TS-212P QTS 4.3.3
TS-212P QTS 4.3.3
Re: TS-212P QTS 4.3.3 Clam AV software manual update
Great!
Thank you for pointing me to the right direction!
Carlos Molina
TS-212P QTS 4.3.3
TS-212P QTS 4.3.3
Just updated the virus database.
I've added the clamavdb.c3sl.ufpr.br mirror site at /etc/config/freshclam.config file and followed the instructions of the post above.
Cheers!
Cheers!
Carlos Molina
TS-212P QTS 4.3.3
TS-212P QTS 4.3.3
