PC Backup to NAS
Discussion about various official QPKG software applications. Login required to view the contents.
part deux
Getting the hang of things
PC Backup to NAS
Post by part deux » Sun Apr 11, 2021 5:03 am
I'm frustrated with Acronis, what worked for years is now failing. Every file it creates, ends up corrupted and fails incremental backup.
Is there a native app on Qnap I can use?
TS453 is reporting normal operations. Wireless network seems to be operating normally.
Any other backup apps I can use?
Moogle Stiltzkin
Ask me anything
Contact:
Re: PC Backup to NAS
Post by Moogle Stiltzkin » Sun Apr 11, 2021 5:53 am
i use aomei backupper to backup from pc to nas.
other popular choices on the qnap community is things like veeam, Syncback, and probly some others.
not sure why your acronis is failing so badly. usually you would contact acronis and inquire why that is the case? :'
make sure after you first backup, to verify that the backup is good or not. always verify :'
NAS
[Main Server] QNAP TS-877 w. 4tb [ 3x HGST Deskstar NAS & 1x WD RED NAS ] EXT4 Raid5 & 2 x m.2 SATA Samsung 850 Evo raid1 +16gb ddr4 Crucial+ QWA-AC2600 wireless+QXP PCIE
[Backup] QNAP TS-653A w. 5x 2TB Samsung F3 (HD203WI) EXT4 Raid5
[Backup] QNAP TL-D400S 2x 4TB WD Red Nas (WD40EFRX) 2x 4TB Seagate Ironwolf, Raid5
[^] QNAP TS-659 Pro II
[^] QNAP TS-253D
[^] QNAP TS-228
Network
Qotom Pfsense|100dl/50ul MBPS FTTH Internet | Win10, WC PC-Intel i7 920 Ivy bridge desktop (1x 512gb Samsung 850 Pro SSD + 1x 4tb HGST Ultrastar 7K4000)
Guides & articles
spile
Easy as a breeze
Post by spile » Sun Apr 11, 2021 2:54 pm
I have only ever used Veeam for client to NAS backup.
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Sun Apr 11, 2021 5:50 pm
seems like qnap are doing a video about veeam, so you should check it out
https://www.youtube.com/watch?v=OXHlx-dOXb0
there should be an english one later
NAS
[^] QNAP TS-253D
[^] QNAP TS-228
Network
Guides & articles
AlFromCochrane
Know my way around
Post by AlFromCochrane » Tue Apr 13, 2021 11:22 am
Might as well throw my favorite pc to nas backup app into the mix. I use Macrium Reflect. They have a free version which is full featured. But as a retired developer, I have no problem buying a lifetime license to support good development.
I have no issues whatsoever with Macrium. Schedule it to create backups during the night and once you have your desired results, nothing to worry about.
cheers :)
best regards, Allan
Firmware Version:Always updated
TS-873 32GB Ram, 8 x 8TB Seagate IronWolf NAS Model: ST8000VN0022,
40 TB total RAID 6 storage pool, 1 Hot Spare, M.2 SSD slots empty, Unit for offsite HDD Backups:
Vantec Nexstar MX NST-400MX-S3R-Utilizing 2x WD 8TB Red),
network services/apps: PuTTY, Media server apps, HBS, Plex .
part deux
Post by part deux » Mon Apr 26, 2021 2:26 am
Acronis customer support is nothing more than script readers. I asked for and received my money back. Internet is flooded with similar reports. Seems the 2021 version really messed the program up.
spile
Easy as a breeze
Post by spile » Tue Apr 27, 2021 5:31 pm
Cheers I look forward to checking it out when it is posted.
Moogle Stiltzkin
Ask me anything
Contact:
Post by Moogle Stiltzkin » Wed Apr 28, 2021 2:50 am
that video was posted like a week ago.
usually an english version of it would be released on the same day in the next couple of hours after. but this seems to be one of those videos where they did not seem to do an english video release :S (it happens sometimes)
i found an alternative video for backing up using veeam to a nas
https://www.youtube.com/watch?v=TxnDnb8DJeI
NAS
[^] QNAP TS-253D
[^] QNAP TS-228
Network
Guides & articles
spile
Easy as a breeze
Post by spile » Wed Apr 28, 2021 2:21 pm
I was referring to the English version but as I have been using Veeam for a number of years without any major issues I have no need for a tutorial as this time.
As an aside, I have one specific issue in that access relies on the use of the default admin account which given recent vulnerabilities is far from ideal. I haven’t checked if Veeam have resolved this.
Return to “Official Apps”
