Continuous request from IP 253.253.253.253 detected by QuFirewall
Discussion about various official QPKG software applications. Login required to view the contents.
touss1coup
Post by touss1coup »
Since yesterday, the QuFirewall application is detecting a lot of continuous blocked requests (65 per minutes).
So I run an events capture and it recorded requests from IP address 253.253.253.253 (see attached picture) and I have no idea where theses requests come from.
I disconnected the LAN adaptater of my NAS and it still recording these requests. So it comes from internal application. I stopped Container station app but still the same.
I checked in Container station settings and there are 2 virtual adaptaters but with differents IP addresses: 10.0.3.1 and 10.0.5.1. So it seems it doesn't from there.
Does someone have an idea where these requests come from?
Thanks.
Jazz59
Re: Continuous request from IP 253.253.253.253 detected by QuFirewall
Post by Jazz59 »
These are multicast requests from a server installed on your Qnap (for example: MinimServer, Emby, Plex, etc.). I have already given the solution to this problem here:
viewtopic.php?f=121&t=160483#p788473
Jazz 8)
Qnap TVS-472XT 32GB | NIC QXG-10G2SF-CX4 | 3 HDD Seagate 6TB | 2 SSD NVMe Samsung 970 Evo 1TB | Drive QDA-A2MAR | 2 SSD Samsung 860 Evo 500GB
touss1coup
I undestrand you choose to accept all requests from 253.253.253.253 then it's not normal you get no more warning since. But how did you identify the source of these requests (Minimserver)? In my case nothing change neither in my NAS configuration neither on my private network. So I assume this is coming from an update of QuFirewall app. Maybe a bug...
Return to “Official Apps”
