I'm running an older TS-869L with the latest firmware (4.3.4.1642). Wondering if anyone can help with the following questions:
1. AppCenter does not offer me the ability to manually update my instaled apps, as per other update instructions I've seen. Shouldn't there be an update button somewhere on this screen?
2. Searching for QuFirewall or QFirewall or firewall in the AppCenter search bar returns no results. Can I install QuFirewall on this NAS?
Update: looks like I need QTS 4.5.1... assuming I can't run that on this NAS? https://www.qnap.com/en/how-to/tutorial ... qufirewall
App updates and where is QuFirewall?
Re: App updates and where is QuFirewall?
Correct, your unit is too old for that QTS version.
But it's dangerous enough to expose even an updated QTS on the internet as have once again recently been shown with the Qlocker disaster. To expose an old unsupported QTS on the internet is madness so I strongly recommend that you don't do that and then you don't really need QuFirewall anyway.
Have come to realise QNAP != internet!!! I think I'm completely off the internet now but was hoping to keep 443 running for MyQNAPCloud and being able to address the NAS through the myqnapcloud.com address (i.e. without a certificate warning from the browser) but yer, would rather keep my data safe! Will have to find another way to sort the cert warning
