Hi all:
My setup is 2 NAS, with my photocollection.
I use my NAS at 2 different location for security against loss.
if I'm at location 1, I can edit tags on the photos, and these changes should be backed up/synched to location 2.
If I'm at location 2, I edit tags, and that should be backed up/synched with location 1.
At the moment,I use HBS3 (RTRR) to sync between the 2 NAS, both ways.
I've set the synch up to "overwrite older files", but unfortunately the file date is not changed when editing tags, only the "Accessed date", so during synch the changed tags are overwritten.
What can I do, to be able to mutually update my NAS'es...really hope you can help?
Greets
synching photos via HBS3 by date accessed
- mitscha
Re: synching photos via HBS3 by date accessed
I'm currently testing and setting up my 2 NAS. Wondering if you found a solution?
[Main Server]
QNAP TS-872X7 (QuTS)
PCIe Gen3 x4: QNAP QM2-2P-344 with 2 x 2TB XPG SX8200 Pro NVMe
8 x WD102KFBX 10TB Red Pro, RAID6
[Backup]
TS-128A
18TB WD181KFGX Red Pro
[Backup]
TS-128A
