Ubuntu Linux Station: Installation is failure (Failed to install built-in packages: kodi)
Discussion about various official QPKG software applications. Login required to view the contents.
MaxGammy
Post by MaxGammy »
I'm setting up a new TS-253D, firmware version 4.5.4.1723.
I've installed Ubuntu Linux Station.
When I try to install Ubuntu 20.04, it stop at 70% and say "Installation is failure".
Looking in the /var/log/container-station/ubuntu-hd.log file form more informations, I found the following error:
[I 210713 21:40:58 distro.pyc:263] {'state': 'processing', 'lxcname': 'ubuntu_2004', 'action': 'install', 'progress': 70, 'config': -1}
[I 210713 21:40:58 distro.pyc:529] Install progress: 70
[I 210713 21:40:58 base_package.pyc:94] install, ['install', 'kodi']
[I 210713 21:40:58 base_package.pyc:152] Reading package lists...
[I 210713 21:40:58 base_package.pyc:152] Building dependency tree...
[I 210713 21:40:58 base_package.pyc:152] Reading state information...
[I 210713 21:40:58 base_package.pyc:152] E: Unable to locate package kodi
[E 210713 21:40:59 distro.pyc:473] Install Error!!
[E 210713 21:40:59 distro.pyc:474] Failed to install built-in packages: kodi
Traceback (most recent call last):
File "middleware_ubuntu_hd/ubuntu_2004/distro.py", line 395, in process
self._system.apt_install(['kodi'], smallprogress(25, 30))
File "middleware_ubuntu_hd/ubuntu_base/base_system.py", line 119, in apt_install
', '.join(pkgs)
Exception: Failed to install built-in packages: kodi
and, at the end of log file:
[E 210713 21:41:03 distro.pyc:571] Failed to install built-in packages: kodi
File "middleware_ubuntu_hd/ubuntu_2004/distro.py", line 567, in install
generate_progress_callback('processing', 60, 40)
File "middleware_ubuntu_hd/ubuntu_2004/distro.py", line 521, in process
raise e
[I 210713 21:41:03 distro.pyc:188] processing -> error (progress=None, errmsg=Failed to install built-in packages: kodi)
[I 210713 21:41:03 distro.pyc:263] {'state': 'error', 'errDetail': {'progress': 70, 'state': 'processing', 'error_msg': 'Failed to install built-in packages: kodi'}, 'lxcname': 'ubuntu_2004', 'config': -1}
[I 210713 21:41:03 base_container_mediator.pyc:223] event:downloading-start
[I 210713 21:41:03 base_container_mediator.pyc:224] state: {"state": "error", "errDetail": {"progress": 70, "state": "processing", "error_msg": "Failed to install built-in packages: kodi"}, "lxcname": "ubuntu_2004", "config": -1}
[I 210713 21:41:03 base_container_mediator.pyc:225] dstate: {"enableState": UbuntuLxcPhase.INIT}
[I 210713 21:41:03 base_container_mediator.pyc:257] event:downloading-start {"enableState": UbuntuLxcPhase.INIT}, nexttick=None
[I 210713 21:41:03 base_container_mediator.pyc:223] event:processing-start
[I 210713 21:41:03 base_container_mediator.pyc:257] event:processing-start {"enableState": UbuntuLxcPhase.INIT}, nexttick=None
[I 210713 21:41:03 base_container_mediator.pyc:223] event:error
[I 210713 21:41:03 base_container_mediator.pyc:257] event:error {"enableState": UbuntuLxcPhase.INIT}, nexttick=None
Do you have any idea about how to solve this issue?
saberjag
First post
Re: Ubuntu Linux Station: Installation is failure (Failed to install built-in packages: kodi)
Post by saberjag »
I'm having the exact same issue on my TS-451A and I'm running the same firmware version. Does anyone have a fix? It's a shame if Kodi is to blame since I don't even want Kodi on my NAS.
marketingvp
First post
Post by marketingvp »
I am having the same issue except now my whole NAS has crashed and won't boot up at all. Occasionally it tells me to initialize the system. I don't want to lose my data and do this. Does anyone have a recovery solution?
Return to “Official Apps”
