I'm sitting trying but I'm giving up. Please help.
I have Qnap 251d and on it Mattermost 5.0.0.7
Due to the fact that this is an old version I wanted to move to something higher such as: in Docker.
Here I have no problems everything works nicely including the internal database but...
How to backup database from this "factory" application?
I checked the files and here:
mattermost\volumes\db\var\lib\postgresql\data
According to me it holds the base. There are others in the base directory (probably with mattermost base) and lots of files there.
I tried on my computer to put in the same version: postgresql, then disable the service replace all the files and enable but then it crashes for me.
I tried connecting to qnap on port 5432 through the pgadmin application but it sees nothing.
In the docker-compose.yml file it is:
- MM_USERNAME=mmuser
- MM_PASSWORD=mmuser_password
- MM_DBNAME=mattermost
So I'm shooting that this is the data for the database.
Unfortunately despite various attempts I am not able to access it. I need to either get into the database or somehow convert the files to sql.
HELP.
Mattermost - Help - Database
Re: Mattermost - Help - Database
never used the app but others seems to have the question as well
https://forum.mattermost.org/t/qnap-mat ... ackup/9870
so you currently have the qpkg (non container) running and no db is showing up in phpMyAdmin?
Thank you for your reply.
It tipped me off to this:
Well okay I think I figured it out a little bit through other versions as well.
It looks like Mattermost is uploaded to the directory:
/share/CACHEDEV1_DATA/.qpkg/mattermost
But the database in postgres is in:
/share/CACHEDEV1_DATA/.qpkg/mattermost/volumes/db
but the application config is in:
/share/CACHEDEV1_DATA/.qpkg/mattermost/volumes/app/mattermost/config
In it we find the entry:
"DataSource": "postgres://mmuser:mmuser_password@db:5432/mattermost?sslmode=disable=u0026connect_timeout=10",
so we have the login credentials (me too before):
login:
mmuser
pass:
mmuser_password
database server name (instead of ip)
db
port:
5432
And up to this point it is ok.
Next the stairs start because it looks like postgres is somehow a Container Station but probably through that:
to me it indicates that the database is not located in a directory somewhere Container Station but in:
/volumes/db/var/lib/
So we have it explained.
What is more, the application is written differently, because we have some things in the directory:
nginx
But now a problem arises.
We know theoretically that the database (postgres server) is located / started via container, but how to connect to it?
Via PuTTY or via some tool such as HeidiSQL by selecting postgresql FAQ SSH tunnel?
How to connect to it?
No.dolbyman wrote: ↑Sat Nov 13, 2021 11:51 pm never used the app but others seems to have the question as well
login:
mmuser
pass:
mmuser_password
db
port:
5432
version: "2"
services:
db:
image: mattermost/db:${BUILD_HASH}
restart: unless-stopped
volumes:
- ./volumes/db/var/lib/postgresql/data:/var/lib/postgresql/data
- ./flags:/flags
- /etc/localtime:/etc/localtime:ro
environment:
- POSTGRES_USER=mmuser
- POSTGRES_PASSWORD=mmuser_password
- POSTGRES_DB=mattermost
app:
image: mattermost/app:${BUILD_HASH}
depends_on:
- db
expose:
- "${APP_PORT_NUMBER}"
volumes:
- ./volumes/app/mattermost/config:/mattermost/config:rw
- ./volumes/app/mattermost/data:/mattermost/data:rw
- ./volumes/app/mattermost/logs:/mattermost/logs:rw
- ./flags:/flags
environment:
# set same as db credentials and dbname
links:
- db:db
system-docker exec -it mattermost_app_1 /bin/sh
# web:
# image: mattermost/web:${BUILD_HASH}
# depends_on:
# - db
# - app
# environment:
# - MATTERMOST_USE_SSL=${MATTERMOST_USE_SSL}
# - APP_PORT_NUMBER=${APP_PORT_NUMBER}
# - Forward80To443=${Forward80To443}
# ports:
# - "${MATTERMOST_HTTP}:80"
# - "${MATTERMOST_HTTPS}:443"
# restart: unless-stopped
# volumes:
# # This directory must have cert files
# - ./volumes/web/cert:/cert:ro
# - /etc/localtime:/etc/localtime:ro
# links:
# - app:app
networks:
default:
external:
nginx
We did it!
Using putty I pasted the command:
I then pinged the name "db" is what appeared here:
This showed me the IP address:
172.30.68.2
It only responded once, every time.
On the Qnap in the virtual switch application I found Virtual switch, there I took off the nat and set the dns to Qnap and router.
Then I added routing on the computer:
route add 172.30.68.0 mask 255.255.255.0 Qnap's IP
From this point it pinged my IP:
172.30.68.2
Then using the program: HeidiSQL
I connected to this address on the port and data that are already known and it works.
I have access to the database!
We did it!
172.30.68.2
172.30.68.2
Any chance to have an idea of to do a backup of the MM db ?
Thank you !
Thank you !
@fnxfnx
That is a great accomplishment.
Could you explain the last part more in detail?
I made it up to the IP of the database but then I lost the plot.
When I try to ping it, it shows
Also the part with what you did on the Qnap with NAT I did not understand.
And what where your settings for the HeidiSQL connection?
PING 172.30.12.2 (172.30.12.2): 56 data bytes
ping: permission denied (are you root?)
