Since i upgraded my TS 439 pro II+ to release 3.7.3 and recreated my SQL DB I can not login in to my Web File Manager. It gives a messages Access Denied.
How can I enter again? Also I can not see all the folders when I use finder on the MAC and look at the folders AFP and SAMBA. it shows the message: The operation can’t be completed because the original item for “Multimedia” can’t be found.
When I look in the Share Folders I see the folders but i can not select them, but the calculate the size of the folders.....
Anyone that can help me here? Is MySQL used for the file management? Can I recreate the links to the folders?
thanks, eric
web file manager access denied
- schumaku
Re: web file manager access denied
No - not at all.ekrol wrote:Is MySQL used for the file management?
Any failure indication in the NAS system log?ekrol wrote:Can I recreate the links to the folders?
Rule of thumb - /etc/smsb.conf (resp./etc/config/smb.conf) corrupted or broken. The symlinks were created at boot-time according to that file - but then, you say the share file system usage is rescanned and r-calculated. Strange.
Please contact QNAP Customer Service...
