Ts-231P
Backup, Restore, Netbak Replicator, Cloud Storage Services
tilen
First post
Ts-231P
Post by tilen »
Hi Qnap,
I have a problem with adding another folder outside of basic qsync folder.
I can't add another folder.
Please help, I have attached a pictures.
best regards
Tilen
darfie21
Re: Ts-231P
Post by darfie21 »
I have a TS-231 as well and can only sync from one folder.
Anybody know how to add additional folders to sync qith qsync
darfie21
Re: Ts-231P
Post by darfie21 »
Ok you cant sync multiple directories to the same share. To Sync additional directories from a client you need to create a new share on the nas. It seems
as though its one client directory per share. Not the best but I believe its how it works.
Return to “Backup & Restore”
