how to handle .streams folders
I've set up an external drive backup job, between a disk inside my TS-431P and an external USB disk.
Every time the backup runs I get messages in the logs saying that files were skipped because they have unsupported file names.
All these skipped files are located in the .streams folder. I have no idea what these files are, or how this .streams folder was created.
When I delete the .streams folder, the backup runs without any errors.
Anyone had this problem before? How do I handle this?
Re: how to handle .streams folders
is it a folder or a share ? .. any printout of such error logs ?
its a shared folder.
this is a screenshot of the logs.
what is your external usb disk formatted as ?
EXT4
NTFS ?
EXT4
NTFS ?
- Easy as a breeze
There are other threads regarding this and for me, it began after installing the officially released version of f/w 4.3.3. I opened a ticket and their answer was to "ignore the error" and claims it will be fixed in the next f/w build which did not happen either.aristosv wrote:I've set up an external drive backup job, between a disk inside my TS-431P and an external USB disk.
TS-212P QTS: 4.3.3.1864 build 20211212
2 x Seagate ST3000VN000 (RAID 1)
@dolbyman all disks are NTFS
@albumman good to know I'm not the only one.
I guess I could set up a cron job to delete the .streams folders before the backup. But that would be a workaround, not a solution.
well the internal disks can't be ntfs
@dolbyman
Do you have a suggestion?
my guess was file name depth of internal ext4 vs external ntfs drives ...
but if it is a known issue wait for a qnap fix I guess
- Easy as a breeze
Did you happen to open a ticket too? Mine got closed awhile back with no fix yet. If not, please open one. Thanks.aristosv wrote:@dolbyman all disks are NTFS
Actually the .streams folder was being copied over to the qnap while backing up my laptop data. Even though I couldn't find this folder on my laptop, after running the backup, it would appear on qnap. So I just modified the backup job to delete the .streams folder on qnap, after running the backup job.
- Easy as a breeze
Brilliant QNAP. I have this strewn over all my shares...
Model: TVS-872XT 16GB
Model: TS-877-1700 16GB
- Moogle Stiltzkin
the check mark "Filter system-generated temporary files" does not filter the .Streams folders!
only with DS_Store, / @ *, /. * entered in Other filters the .streams folders were skipped.
mfg
Olaf
https://forum.qnapclub.de/thread/43995-ordner-streams/Hello,
I'll try to shed some light on the subject.
The ".streams" folder is created by SAMBA - this is the software that can create Windows shares under Linux and controls CIFS / SMB access for the Windows systems.
In the ".streams" folder, the Alternate data streams are stored by the NTFS - here, for example, Windows determines whether a file has been downloaded from the Internet and displays corresponding warnings. Since Linux / EXT4 does not know Alternate data streams, SAMBA has to drop the ADS somewhere - and that happens in the .streams folders. The problem with deleting the folders is that SAMBA - and thus Windows - lose all information stored in the ADS.
So, I hope I was able to clear up a little bit - for more details I can recommend the Wikipedia to NTFS.
LHS
[youtube=]qBrFW3gpjpM[/youtube]
they ought to include this type of explanation into the FAQ imho
https://www.qnap.com/en/how-to/
NAS
Network
Resources
Network
Resources
- Easy as a breeze
I suppose this isn't possible, but what would be really nice is if Samba didn't write any .streams at all when going to ext4. Anyone know if it's possible? I didn't find anything in the Samba configuration to disable writing .streams.
As far as I can tell the data is useless and I have setup a cron job to delete them each day.
