I want to use my TS-451 to backup my OneDrive files.
Hybrid Backup Sync can be setup easily. I use Mirror. My OneDrive has about 17K files. 49GB.
I had run this for 2 days and the majority of the files have been mirrored, but was interrupted.
While running I would be luck to see download rates of 90-100 KBps. I have 100Mbps internet.
I start it again and now 2 Hours running and it is still calculating and not even started transferring.
I can manually copy the files faster in File Station.
What am I doing wrong?
Hybrid Backup Sync from OneNote to TS451 Very Slow
Re: Hybrid Backup Sync from OneNote to TS451 Very Slow
Follow-up ... 2.5 hours now completed "calculating' and in running mode now. Estimated completion is 2043. Transfer a Bytes per second, not even KB. UGH.
Job Status and Logs
Status
Status: Running (39/6695)
Remaining files to be processed: 6658
Remaining data to be processed: 27.55 GB
Current data upload rate: 28.36 Bps
Current data download rate 25.08 Bps
Number of files transferred: 37
Total size of files transferred: 54.24 MB
Start time: 2017/05/29
Progress: 0%
Estimated completion time: 2043/10/01
Job Status and Logs
Status
Progress: 0%
- OneCD
Find a comfortable chair and a good book.Mocktwo wrote:Estimated completion is 2043.
