TS-853A
4.3.3.0238 (latest)
Hybrid Backup - 2.1.170630 (latest)
I am backing up to Amazon Glacial and I need to rate limit the backup during working hours.
My maximum upload is 1.8 MBps. I need to rate limit at 1.4 MBps to prevent bottlenecking.
When I go to profile and apply a rate limit. Whole numbers work fine. I.e. 1000 KBps or 1 MBps.
BUT decimal points do not. Any decimal results in no limit. i.e 1.4 MBps results in no rate limit.
The maximum KBps entry is 1000. So I cannot use 1400 KBps to fine tune the limit.
Any thoughts?
Rate Limit for Hybrid Backup not working
- Moogle Stiltzkin
Re: Rate Limit for Hybrid Backup not working
just one ... oo 2. remember check my faq link for creating support ticket.DHOMD wrote:Any thoughts?
your welcome
http://www.attinternetservice.com/resou ... s-vs-mbps/
Last edited by Moogle Stiltzkin on Fri Jul 14, 2017 8:30 am, edited 1 time in total.
NAS
Network
Resources
Network
Resources
Is it really 1.8 MByte/sec? Did you measure it to be exactly that? If not where does that number come from?DHOMD wrote:My maximum upload is 1.8 MBps.
I must ask as I've never seen any ISP specifying the bandwidth in Bytes per second, they always use bits per second.
@P3R Hybrid records bandwidth by default in bytes not bits. So I am just using their default bandwidth terminology.
Since I upload about 6 TB a month, I get a great rolling average, 1.84 MBps (15 mbps if you prefer) is essentially the practical upload cap of my ISP.
I sent in an email to that find a bug competition... hopefully it gets resolved.
Yes, and hopefully you win the prize as well!DHOMD wrote:I sent in an email to that find a bug competition... hopefully it gets resolved.
