I just set it up with QTS 4.3.3.0238. I am backing up large image backup file from Acronis. Just that one file. 24 hours in, it has done this. 2 times in a row. To the minute.
[CloudBackupSync] (Sync) job failed because of a cloud storage authentication error. Please re-login your account.
I don't even need to relogin. I can just restart backup, but it basically starts over, uploading file from scratch, unable to finish because of this. Any help is much appreciated. I prefer not to be uploading until time indefinite.
I'm getting exactly the same problem on a few of my backup jobs, but not all of them! (settings are the same apart from which folders are copied from/to)
Same issue. Failing just after 24 hours. I think it relates to the backblaze b2_authorize_account API call. Tokens are only good for 24 hours, so uploads are being terminated once the token expires. I don't see any setting that would trigger a refresh, so, if this is the issue, QNAP would need to provide an update that would get a new token before the current one expires.
As a potential workaround, I am trying another upload, but I bumped the Concurrent processing files from 5 to 8 (Advanced Job Settings). Maybe if the job processes more files at once, the upload will finish before 24 hours. Doubtful, but worth a shot.
Hi guys, I also noticed this and have sent the following ticket to QNAP support (see below).
So far quite a miserable experience working with the support from QNAP (excellent examples on how NOT to treat basically free bug reports for your applications). I'm currently running a new job to see if the new firmware solved it. I don't think so (because I could not see this bug being mentioned on the release for the Hybrid Backup Sync app) but I promised the support guy I'd give it a shot.
In the meanwhile, you can simply restart the job. Files will have been uploaded in those 24 hours. My job now takes less time than the 24 hours and it now works fine. You simply have to re-run the job to feed that initial data. Hope this helps someone out there.
My mail to support:
First of all, I'm testing the new Hybrid Backup Sync application and I really like it. I'm currently using it with Backblaze as the cloud storage. This works fine except for one thing: a sync job will end with an error after 24 hours. See the following message from the log.
Server Name: QNAPTS219P
IP Address: 192.168.0.11
Date/Time: 2017/07/24 11:00:36
Level: Error
[CloudBackupSync] (Sync) job [Backblaze B2 backup - Foto] failed because of a cloud storage authentication error. Please re-login your account.
This happens because I think you are using the API from Backblaze incorrectly. When starting to use the API (which is necessary for uploading files to Backblaze) you have to authenticate. When you have authenticated, Backblaze will give you a token which then has to be used for all the further API-calls during the session.
This token only has a lifetime of 24 hours. So if a job runs longer it will run into this situation. The correct way to handle this error popping up is to re-authenticate and use a new token.
So whenever an operation fails with the following HTTP error, the best way to handle this is to authenticate again, get a new token and try the last operation again.
401 expired_auth_token Authorization token has expired
Would really appreciate it if you could fix this in an upcoming update.
QNAP told me that they are fixing this issue for next version of Hybrid Backup Sync, due out at a date TBD. They indicated as much as a month, possibly.
For me, redoing sync didn't work, probably because I was only syncing one file. It just redid the file, instead of continuing it. I'll just be waiting for the new version, rather than split my file up.
Just finished my test today - the new firmware does *not* yet fix this bug. I would advise everyone to monitor the releasenotes of the hybrid backup sync application.
I also suspect that this issue will not be solved with a firmware update but with an update of the hybrid backup sync application. The helpdesk said that they would transfer this issue to the R&D team in Taiwan.
It's been a couple of weeks since I have looked at this, but switching to a mirror action (instead of copy) allowed me to get everything synced to B2. still took over 24 hours and failed, but restarting the job did allow for the job to pick up where it left off. As you pointed out Iceman, I don't know if this would work for a single file. Glad QNAP has it on their radar at least. Thanks Wilbert for submitting a ticket.
I just want to say that with Hybrid Backup Sync version 2.1.170818, I'm still having this timeout/authentication issue.
It's really annoying because it fails on a large file (a 50GB one) after uploading at 300KB/s (about 1/10 of my upload speed) because it's only a single thread/file I think.
TVS-872XT-i5-16GB with 6*ST12000VNZ008 in RAID 6.
Backed up to a stack of a half dozen 'cold' external 12TB and 8TB HDDs - please back up your data, RAID is not the same as a backup!
Formerly TVS-463 with 4*WD60EFRX in RAID5, planning to reuse as an additional backup destination in the new year.
All protected by an APC SMT750VA UPS - protect your NAS from bad power!
Yeah. I'm still getting the 24 hour (and 2 minute) timeout issue.
Once made it to 48 hours at 2 minutes, but that was a one off, I think.
I heard about some new Java SDK that is supposed to be able to auto-renew the authorization token. Does anyone know if this is something we are relying on QNAP in integrating and a timetable on this happening?
