I have been using OneDrive for Business beta to sync my work data to my QNAP NAS box but of late it has not been able to authenticate. Now when I try and reinitialise it I only get his message. I have contacted Microsoft who have said I should ask here.
Any help would be great.
Jonathan
Hybrid Sync problem with OneDrive for Business
Re: Hybrid Sync problem with OneDrive for Business
I just set up OneDrive for Business as well on my QNAP TS-269 Pro to Sync some Data and I had no problems to set that up. Are you running on the latest Firmware on your QNAP?
