I was hoping that Hybrid Backup Sync would retain previous versions stored to Backblaze B2 as it's supported by both the B2 API: https://www.backblaze.com/b2/docs/file_versions.html and web interface: https://www.backblaze.com/blog/backblaz ... cle-rules/
According to QNAP Support, HBS deletes any previous version of a file or folder intentionally and then replaces it with the latest version. Support advised to submit a 'feature request' for previous version retention to be added in the future.
HBS to B2 does not retain previous versions
- peelos
- Been there, done that
Re: HBS to B2 does not retain previous versions
thanks, did you submit a feature request?
NAS: TVS-1282-i7-7700-40G / 4 x 500GB SSD 2.5" RAID 10 / 2 x 500GB M.2 SSD / 8 x 12TB WD Whites 3.5" RAID 6 / Noctua L9x65 / 3 x 80mm PWM Noctua fans / Corsair 600W PSU / Asus Turbo GTX 1060 6GB GPU
Software: Plex Media Server / Transmission / Sonarr / Radarr / Bazarr / Jackett / Tautulli / Home Assistant / Resilio Sync / Python / NetData / SortMyQPKGs
pfSense Firewall / OpenVPN Server: QOTOM Fanless Mini PC / Core i5 / 8GB RAM / 128GB SSD / 4 Gigabit NICs / AES-NI
Wireless Routers: 2 x Netgear AC1900 R7000 Nighthawk / 1 x Netgear AC3200 R8000 Nighthawk / FreshTomato Firmware
So how do you backup (properly with versioning supported / enabled) from QNAP to Backblaze B2?
I'm using the Sync option on HBS and yea it seems to delete and replace any updated files instead of making a new version of them.
QNAP TS-459U+
Firmware Version 4.2.6 Build 20170905
