Hi All
Can you help me understand how rsync works in QNAP? During my tests, I could only get one-way synchronization from local to remote NAS. Is it possible to get this working in opposite way (remote to local) or get two-way sync?
This is how it is now:
NAS1-->NAS2
These are my RSync server settings. RSync servers are running on both devices but as far as I understand just one remote server (NAS2) should be enough.
I'm not sure which credentials should I enter here, manual says:
"Enter the username and password to authenticate the Rsync server which attempts to back up data to the NAS."
Whatever I enter it doesn't get me any additional option to do NAS2-->NAS1 sync.
G.
Rsync two-way sync
Rsync two-way sync
- storageman
Re: Rsync two-way sync
RTRR is two way sync
True.
But Rsync is preferred option as it could work in block level mode (I want use NAS-to-NAS option) rather than file level like RRTR.
If two-way sync is impossible, maybe there is a way to set a one-way sync but remote server to a local one?
G.
G.
No. NAS to NAS/Rsync only work with push not pull.Glikogen wrote:...maybe there is a way to set a one-way sync but remote server to a local one?
RTRR can do pull as well but as you say, it's file based.
- storageman
Run RSYNC on a slow processor and I can guarantee you that RTRR is faster, especially if files are relatively small.
RSYNC is only good on faster processor where the block comparison works faster or predominantly large files.
Sure you can RSYNC to eachother NAS but watch out not at the same time and not with files open.
On very slow (often WAN) connections Rsync is the only usable alternative regardless of CPU but on gigabit LAN and better I agree with storageman.
Totally agree -
a shame there is not a pull backup option and exclusions option in Rsync coded in Hybrid sync Backup. it would make backups much easier instead of manualy setting things up in a terminal.
And please get rid of the so called "create job" routine.
Why not have one page with al the options visible .
Simply gray out what is not able to be selected anymore if one option above is selected.
Having one fast backup station that controles backups for other nas systems to do a backup to makes it way easier to control what is running at what time.
