Hi.
In the file manager logged in with a normal user i can see my home folder (the one from /home/username ) and the Multimedia folder.
I want to set up a OneDrive Sync Job in Cloud Drive Sync but i cannot choose any Local Location other than the Multimedia folder.
I don't understand if this is a bug or a feature.
If it is a bug, i think the Cloud Drive Sync does not list symlinks in the Local Location folder browser.
Thanks.
Cloud Drive Sync : Local Location question
Re: Cloud Drive Sync : Local Location question
I have the exact same problem an that is very annoying!
With some previous version of Cloud Drive Sync i was able to create Jobs in my home folder (and there are some still running)...so I think this is a bug...
Anyone found a solution? Is there any workaround?
