In order to backup the data from a TS-219p to the cloud I am currently searching for a (hopefully integrated) solution. If I understand correctly the build in backup app can already backup to cloud services. Is there any storage service provider that you can recommend that has a datacenter in Germany? Will the data be automatically encrypted for storage and securely transferred?
Thanks for any advice.
Backup to cloud with datacenter in Germany
Re: Backup to cloud with datacenter in Germany
Not sure about the encryptions but I'm sure the provider can confirm.
Below is locations of both Google and Amazon Cloud, this what you're looking for?
https://cloud.google.com/about/locations/
https://aws.amazon.com/about-aws/global-infrastructure/
QNAP TS-459U+
Firmware Version 4.2.6 Build 20170905
Hetzner Storage Box. Recommended!
Hetzer Storage Box looks promising. Will it work flawlessly with the QNAP Cloud Backup App?
As for Google or Amazon cloud: are those preferable because they integrate better with the QNAP software?
