How can I set Backup Station to backup the files in my /share/MD0_DATA/.qpkg folder?
using Backup Station for MD0_DATA folder
Model name TS-219P II
Total memory 503 MB
Firmware version 4.3.3.0570 Build 20180528
Total memory 503 MB
- OneCD
Re: using Backup Station for MD0_DATA folder
I am doing the following command to copy everything from the .qpkg folder to a folder called QPKG on my Download folder on my external SATA drive that Backup Station also uses:
Speed of copy reports 1.6 MB/s, which seems slow....
rsync -avrhtu --progress /share/MD0_DATA/.qpkg /share/external/sdya1/Download/QPKG
Total memory 503 MB
Total memory 503 MB
- OneCD
Why don't you perform a recursive file copy?ckahn wrote:I am doing the following command to copy everything from the .qpkg folder to a folder called QPKG on my Download folder on my external SATA drive that Backup Station also uses:
Something like:
cp -r /share/MD0_DATA/.qpkg /share/external/sdya1/Download/QPKG
Would that be faster?OneCD wrote:Why don't you perform a recursive file copy?ckahn wrote:I am doing the following command to copy everything from the .qpkg folder to a folder called QPKG on my Download folder on my external SATA drive that Backup Station also uses:
Something like:Code: Select all
Total memory 503 MB
Total memory 503 MB
- OneCD
Try it and see for yourself.ckahn wrote:Would that be faster?
