Using Hybrid Backup Sync on my QNAP TS-212 - have been working fine, but now I am not able to open the app when administering my NAS.
All other apps are opening fine, but when I try to open Hybrid Backup Sync nothing happens ...
HBS version 2.1.180207 and my NAS is on QTS 4.3.3.0404
Can someone help on this??
/ Dan
Hybrid Backup Sync - Problem opening app
Re: Hybrid Backup Sync - Problem opening app
I am having the same issue. When I click on the app, nothing happens. TS-809PRO QTS 4.2.6
Glad to hear, that I am not the only one - hoping for a solution, because I need access to the settings ...fapel wrote:I am having the same issue. When I click on the app, nothing happens. TS-809PRO QTS 4.2.6
/ Dan Sletten
Works here on a Qnap TS-459 Pro II running QTS version 4.2.6 build 20171208 and HBS version 1.3.170914.
UPDATE - problem solved when I just now received notice of an update to HBS version 2.1.180327.
Now the app opens and works fine again
/ Dan
/ Dan
Had the same problem / solution as dsletten. Now have additional problem; may be related to sketchy Hybrid Backup Station code; starting new thread titled "Hybrid Backup Station Can't See Backup Jobs After 2.1.180327 Update"
TS-453 Pro | QTS 4.3.4.0537
I have the same issue on my old TS-112. Sync jobs are still executed, I just can't open the app. It's the lates version and issue still persists.
So what exact version do you have? Is it really the one that solved the issue for the others more than a year ago?
