How does HBS handle this ?
- spikemixture
- Been there, done that
I back up my media from my Qnap to a Synology using Rsync.
I have a 10GBE connection between the 2
Qnap 10.10.10.10 and Syno 10.10.10.17
I also have gigibit connections
Qnap 192.168.1.112 and syno 192.168.1.117
I have about 10 schedule jobs
movies, home videos, other videos, kids etc
What i want to know is what ip is the Qnap using
I can set the Synology to receive on either 10.10.10.17 (10GBE) or 192.168.1.117 (1G)
Obviously i would like the Qnap to send via the 10GBE connection.
How does Qnap decide which ip to send FROM
I have open qnap on 192.168.1.112 and set up jobs
Then I have opened the Qnap on 10.10.10.10 and created a job.
Hard to really tell but it appears a little faster!
Am I dreaming ?
Does it make any difference ?
The reason I ask is am upgrading drives on both boxes. ( and yes I know things are going on in the background)
The syno I had to start from scratch so am copying 28TB from the qnap to the syno.
The speeds are terrible !
It doesn't make any difference if I run 1 job or 6 the speeds hardly change!
I am getting like 5 MB/s at the best and that is from 10.10.10.10 (qnap 10GBE) to 10.10.10.17(Syno 10GBE)
Am I dreaming ?
Qnap TS-1277 1700 (48gb RAM) 8x10TB WD White,- Raid5, 2x M.2 Crucial 1TB (Raid 1 VM),
2x SSD 860 EVO 500gb (Raid1 QTS), 2x SSD 860 EVO 250GB (Cache), 2x M.2 PCIe 970 500gb NVME (Raid1 Plex and Emby server)
GTX 1050 TI
Qnap TVS-1282 i7 (32GB RAM) 6x8TB WD White - JBOD, 2x M.2 Crucial 500gb (Raid1 VM),
2x SSD EVO 500gb (Raid1 QTS), 2x SSD EVO 250gb (Raid1 Cache), 2x M.2 PCIe Intel 512GB NVME (Raid1-Servers)
Synology -1817+ - DOA
Drobo 5n - 5x4TB Seagate, - Drobo Raid = 15TB
ProBox 8 Bay USB3 - 49TB mixed drives - JBOD
All software is updated asap.
I give my opinion from my experience i.e. I have (or had) that piece of equipment/software and used it!
GTX 1050 TI
- Moogle Stiltzkin
Re: How does HBS handle this ?
does this help?spikemixture wrote: ↑Thu Jul 25, 2019 12:17 pm I back up my media from my Qnap to a Synology using Rsync.
Am I dreaming ?
viewtopic.php?f=182&t=149605
someone was asking how to make the traffic use the 10gbe cables for the transfers.
Toxic17 wrote: ↑Tue Jul 23, 2019 5:17 pm My understanding is, if the 10GbE card is on the same subnet, then nas will use the "default" gateway port of the NAS for data transfer.
As dolbyman stated it is better to have both 1GB ports on one Subnet and the 10GbE card on another subnet. that way both subnets will and can have different Gateways. Also if you use protocol binding, you need to have two subnets for it to work correctly.
NAS
Network
Resources
Network
Resources
- spikemixture
Isn't that what I am doing?
the 10gbe is 10.10.10.*
and the 1g is 192.168.1.*
GTX 1050 TI
GTX 1050 TI
- Toxic17
what version of HBS are you using. the HBS 3 (beta) allows for faster transfer of data.
https://www.qnap.com/solution/hbs3/en/
using it here. you wont see that actual files on your backup NAS as these have been Deduped. which converts them to .qdff files. you can however extract them using the QuDedup Extract Tool.
you need to setup your jobs again as I found no way of using an existing v2 backup task and enabling QuDedup in the task. it was greyed out.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
- spikemixture
I am on Version 2.1 190709
I want identical folders/files on the receiving NAS as i use that as a backup server - so it need to see the files the a same as the Qnap.
Does V3 do that or it leaves then as the qdff files - if that is the case no good for me.
So back to my question!
GTX 1050 TI
GTX 1050 TI
- Toxic17
the quick answer - via routing tables, just like most devices.
ssh into your NAS.
type
route
Regards Simon
Qnap Downloads
Qnap Downloads
- spikemixture
/mnt/HDA_ROOT/.config$ route
Kernel IP routing table
Destination Gateway Genmask Flags Metric Ref Use Iface
default 192.168.1.1 0.0.0.0 UG 100 0 0 eth0
10.0.3.0 * 255.255.255.0 U 0 0 0 lxcbr0
10.0.5.0 * 255.255.255.0 U 0 0 0 docker0
10.10.0.0 * 255.255.0.0 U 0 0 0 eth4
127.0.0.0 * 255.0.0.0 U 0 0 0 lo
192.168.1.0 * 255.255.255.0 U 0 0 0 eth0
192.168.1.0 * 255.255.255.0 U 0 0 0 eth3
192.168.1.0 * 255.255.255.0 U 0 0 0 qvs1
192.168.1.0 * 255.255.255.0 U 0 0 0 qvs0
None of those I recognize!
And
GTX 1050 TI
GTX 1050 TI
- Toxic17
you have the choice of using qdff files or not in HBS3 jobs.
Regards Simon
Qnap Downloads
Qnap Downloads
- Trexx
Also depending on how your jobs are configured (compression, etc.) the "computational overhead" of the job itself may be throttling your backup more so than the NW bandwidth.
Paul
UPS: CP AVR1350
UPS: CP AVR1350
- Moogle Stiltzkin
QuDedup technology unveiled: Data deduplication, data size reduction & deduped data direct view @9:17. @17:55, @20:00, @23:38, @29:15
https://www.youtube.com/watch?v=OM--u98cPv8
NAS
Network
Resources
Network
Resources
- spikemixture
Ok running V3 and looks to be an improvement.
Doing a straight sync and it does none of the new fancy name change stuff .
BUT It clearly shows my qnap is NOT using my 10.10.10.10 10GBE ip
But my default 192.168.1.112
My receiving IP Syno shows the 10.10.10.17 correct 10GBE IP.
How do I get Qnap to use the 10gbe ip ?
GTX 1050 TI
GTX 1050 TI
- spikemixture
How does HBS handle this ? [Solved but not really]
Here is the answer
Login using your 10GBE ip (but it must be from a PC on same subnet - in my case my PC on 10.10.10.100)
For me the usual is 192.168.1.112 and my 10GBE is 10.10.10.12
So I opened a new page with that IP and all the jobs in HBS V3 show 10.10.10.12 as the source.
Tests show no speed increase !!
Although HBS V3 show 10.10.10.12 when i open from that IP and 192.168.1.112 shows that IP(192.168.1.112) if opened at the same time it seems to make no difference to anything !
GTX 1050 TI
GTX 1050 TI
- spikemixture
Has anyone connected two 10gbe adapters using HBSv3?
GTX 1050 TI
GTX 1050 TI
- Toxic17
Yep.
Regards Simon
Qnap Downloads
Qnap Downloads
- spikemixture
Do u have the 10GBE as the only ethernet adapter in each of the 2 boxes?
GTX 1050 TI
GTX 1050 TI
