Updated HBS3 from HBS2. It is in "loading Please Waite state"
During the update it gave me warning " Message: [Hybrid Backup Sync] Failed to complete system migration." How I can downgrade it? Please help, I do not know what to do next. Thank you!
- Toxic17
Re: Updated HBS3 from HBS2. It is in "loading Please Waite state"
if its failed have you tried downloading hbs from the app center and reinstalling it to your unknown NAS?
https://www.qnap.com/en-uk/app_center/
btw you posted the OP 12:46, and then 12:55 again asking for people to respond immediately. that aint gonna happen. this is a community forum. Not 24/7 Tech support.
Regards Simon
Qnap Downloads
MyQNap.Org Repository
Qnap Downloads
My NAS is TS-670, yes I did try to install it again without removing it at first place. If I remove it all my setting will be gone . Same result after installing it again.
Thank your for your replay.
Is there any way to downgrade it?
- Moogle Stiltzkin
gdgebuadze wrote: ↑Sat Aug 03, 2019 8:08 pm My NAS is TS-670, yes I did try to install it again without removing it at first place. If I remove it all my setting will be gone . Same result after installing it again.
TS-670 EOL up to qts 4.3.6
https://www.qnap.com/en/product/eol.php
you should check if the app is compatible via qts appcenter.
the alternative is check here (although i recommend the first method)
https://www.qnap.com/en/app_center/?II= ... at_choose=
your qnap is using an outdated qts, and i doubt lots of the apps will be in working condition by 2012-12. time to plan a nas upgrade
NAS
Network
Resources
Network
Resources
I did download "posting.php?mode=reply&f=15&t=149785" previous version and got error "Cannot downgrade Hybrid Backup Sync." Why qnap publish the update for my NAS if it does not work, so frustrated...
Thank you. Moogle
I got exactly same issue after upgrade.
My firmware is at latest 4.3.6.0993
Model TS-453BU
Anyone has any solution for this?
Model TS-453BU
Same problem... It keeps comming with the loading screen. Also got a migration error when upgrading from 2.1->3.
Removed version 3 and installed 2.1 again: https://download.qnap.com/QPKG/HybridBa ... x86_64.zip
Best Regards, Robin
Best Regards, Robin
- Toxic17
I suggest you raise a ticket with QNAP.
Regards Simon
Qnap Downloads
Qnap Downloads
TS-451+ with latest firmware - and happening here.
Tried upgrading from 2.0
Tried fresh install of v3.
Still spinning the loading please wait.
Like me a setups is probably not compatible now they are forcing users who used version to use Qdedup..
Only way I got to work was delete app. reboot. Re install.
Then start over messing up months of backups.
I noticed that the HBS folder "/share/CACHEDEV1_DATA/.qpkg/HybridBackup/" was owned by one of the user accounts on my NAS, and not by "admin" as per all other apps.
I chowned it back to admin. But still has same problem.
