Skipped Files - HBS3
Is there a way to get the list of skipped files when a Hybrid Backup Sync Version 3 runs a backup job?
Re: Skipped Files - HBS3
Did you ever get an answer to this?
I'm just running a sync NAS to NAS using HBS3 for the first time (I previously used the old backup tool for NAS to NAS sync). HBS3 is skipping files (over 3000 so far) even though I have "Don't Apply Filters" and "Include hidden files and folders" both selected and "Exclude system-generated temp files" unchecked - which I would assume means it should copy everything.
-edit-
I just stopped and restarted the job - and now it's skipped a lot more, so it appears to count files as skipped if they're already at the destination.
-edit-
TS-853 Pro; TS-859 Pro; TS-409
Yes.
