Hi All.
Previous to HBS3 we had an active two way sync between a local folder & a folder on our 2nd NAS system at different site.
Change something in either of them, any time & it would instantly be reflected in the other.
Since updating to HBS3 this sync job has ceased to work. .
So I deleted it & made a new active sync job. .
Problems are:
1 - it seems to be only one way
2 - it's not "active" . . I haven't put anything in the "schedule" my thinking being because it's "active" & therefore running all the time. .
What's going on . Any help much appreciated . .
HBS3-ACTIVE SYNC . . ?
Dual identical systems at different post codes comprising:
TS-EC2480U-E3-4GE-R2/240TB-SGT 24 X SGT Disk 10TB SATA III 7.2k 3.5”
+ 2 x
REXP-1620U-RP/160TB-SGT 16 Bay 16 X SGT Disk 10TB SATA III 7.2k 3.5"
+1 x
TL-R1620Sep-RP 16 SGT 16TB Exos X16 SATA 6Gb/s
+ 2 x
+1 x
Re: HBS3-ACTIVE SYNC . . ?
If you created a an Active Sync Job I'm not surprised that it's one-way. Active Sync could also (maybe better?) have been called a Pull Sync Job as it's a pull (data incoming) one-way sync it does.
The job type named One-way Sync Job is a push (data outgoing) one-way sync.
What you should create ia a Two-way Sync Job:
Both Active (Pull) Sync and Two-way Sync Jobs need to be either scheduled (you can make it repeat with an interval of your choice) or manually started. Neither job type is constantly running.2 - it's not "active" . . I haven't put anything in the "schedule" my thinking being because it's "active" & therefore running all the time. .
Hi P3R.P3R wrote: ↑Tue Sep 17, 2019 8:13 pmIf you created a an Active Sync Job I'm not surprised that it's one-way. Active Sync could also (maybe better?) have been called a Pull Sync Job as it's a pull (data incoming) one-way sync it does.
HBS3_2-way.jpgBoth Active (Pull) Sync and Two-way Sync Jobs need to be either scheduled (you can make it repeat with an interval of your choice) or manually started. Neither job type is constantly running.2 - it's not "active" . . I haven't put anything in the "schedule" my thinking being because it's "active" & therefore running all the time. .
Thank you for your clear & succinct reply. .
All is clear now. . . I will set up a 2 way sync job. . .
May I ask though, previous to HBS3, we did have a job syncing/mirroring these 2 folders that I thought was continuously doing so . .
Is that now no longer possible ?
.[/quote]Both Active (Pull) Sync and Two-way Sync Jobs need to be either scheduled (you can make it repeat with an interval of your choice) or manually started. Neither job type is constantly running.
So can a one way job be continuous ?
+ 2 x
+1 x
+ 2 x
+1 x
I have never used 2-way sync so I don't know what was possible in previous HBS-versions.
Ok.
Thanks.
Thanks.
+ 2 x
+1 x
+ 2 x
+1 x
