QSYNC can not connect (Login Failure)
Backup, Restore, Netbak Replicator, Cloud Storage Services
ntkntk
First post
Post by ntkntk »
Hello
I use the latest QSYNC Windows client with VPN connection to a Mikrotik router.
I have connectivity and access to the QNAP NAS trough the VPN connection, but when I try to connect via QSYNC client to the internal private IP of the NAS, after long waiting - about 5 min I receive the following error.
"Login failure". The password is OK and I have permissions to use the QSYNC in the QSYCN central.
My questions are:
1. How to debug this problem?
2. What can be the reasons to receive this "login failure"
3. Why so long timeout? Do my client "sees" the QNAP nas?
4. why there is nothing for my IP or username in the "System logs" application in the web interface?
5. What are the ports used by QSYNC client to connect to the server? Why this information is hidden from the QNAP?
Anyone can advise me and help me to solve this problem?
regards
Nikolay
glpallai
First post
Re: QSYNC can not connect (Login Failure)
Post by glpallai »
I have the same problem, pls help!
Fudge Brownie
Post by Fudge Brownie »
I have this same issue. I have one iMac that can connect and another MacBook that cannot. Did anybody provide a resolution? Thanks.
PJGM
Easy as a breeze
Post by PJGM »
I have the same problem too
QNAP TS-239Pro II+ w/ 2 x WD 3TB Red WD30EFRX in JBOD |FW: 4.2.6
QNAP TS-469Pro w/ 4 x WD 4TB Red WD40EFRX in RAID 5 |FW: 4.3.4.1129
jonmjauu
First post
Post by jonmjauu »
I have the same problem too :(
winnertaco
Post by winnertaco »
Same problem!!!! 569 Pro firmware 4.3.4.1632
My qsync stop working. all client disconnected and when i try to reconnect i receive a message: wrong user name and password
Tried to reset all password and recheck all setting in Qsync, it's ok but not working!
Tried with different versions of clients (4.5, 5.0 and 5.1) same issue
Client mix windows 10 and windows 8
spile
Been there, done that
Post by spile »
I would recommend opening a call and posting the response and resolution here.
aldodemi
Post by aldodemi »
Same here, ticket opened, waiting for answer
gzornetzer
Post by gzornetzer »
Same problem. All my Qsync clients fail to connect after an upgrade to 4.3.4.1632 build 20210324. Doesn't matter if you connect via http or https. Access via web browser and samba shares still works properly. Password reset does not help.
I've also filed a ticket.
RuthBeat
First post
Post by RuthBeat »
Downgrade firmware to 4.3.4.1463 solves the problem in my case.
PJGM
Easy as a breeze
Post by PJGM »
RuthBeat wrote: Sun Apr 11, 2021 12:08 am Same problem. All my Qsync clients fail to connect after an upgrade to 4.3.4.1632 build 20210324. Doesn't matter if you connect via http or https. Access via web browser and samba shares still works properly. Password reset does not help.
I confirm, downgrade to 4.3.4.1463 firmware solves the problem.
pjgm
aldodemi
Post by aldodemi »
Downgrading to 4.3.4.1463 firmware version worked also for me.
market.sk
Contact:
Post by market.sk »
You downloaded the older version here:
https://www.qnap.com/en-us/release-note ... 3/20201006
and that zip file?
QTS build. (Https://download.qnap.com/QPKG/CF64_0.1-1114.qpkg.zip)
I've never had to go to an older version ...
gzornetzer
Market.sk: that does not appear to be the right link.
I recommend going to the qnap download center: https://www.qnap.com/en-us/download (for US english, or the appropriate variant for other countries). Put in your NAS model info and select 'operating system'. You should see a bunch of options, sorted by release date with the newest on top. Select the second from the top, which should have been published in October 2020. For mine, it's: https://us1.qnap.com/Storage/TS-469/TS- ... 4.1463.zip
And the search layout for a QNAP TS-469 pro is: https://www.qnap.com/en-us/download?mod ... y=firmware
Good luck.
As others have noted, downgrading to the Oct 2020 release works. I can confirm for the TS-469 pro.
My ticket also got a response from QNAP indicating that they're looking into it.
janpolet
Easy as a breeze
Contact:
Post by janpolet »
Same issue with the 469L :(
Downgrading firmware to 1463 worked as a workaround.
MAIN NAS: QNAP TS-453D 8Gb | FW: QTS 5.1.4.2596 build 20231128 | 4 x 4Tb Seagate IronWolf Pro (ST4000NE001) in RAID5
BACKUP NAS: QNAP TS-469L | FW: QTS 4.3.4.2451 build 20230621 | 4 x 3Tb Seagate Constellation ES.3 (ST3000NM0033) in RAID5
FIRST NAS: QNAP TS-439 PRO | FW: QTS 4.2.6 build 20230621 | 4 x 1Tb Hitachi/Samsung in RAID5
Locked
Return to “Backup & Restore”
