I have a TVS-872XT and an older TS-851 for backup, both running on the newest QTS 4.4.3.1354.
On both NAS, hybrid backup sync V3.0.200529 is installed and was running for months now, but suddently on the TVS-872XT HBS 3 does not open anymore. If I open the app, the app-window shows its main page in a bit a darker shade, and freezes.
I deleted and reinstalled HBS 3, I even fully reinitialized the NAS and setup everything again. I even downgraded the firmware to previous 4.4.2.1320.
The result is always the same.
On my older TS-851 HBS3 works fine. Any clue or suggestion what else to try?
best regards
Rainer
HBS 3 does not start (app remains dark)
TVS-872XT, 8x Exos 16TB Raid6, 2xCrucial NVMe 1TB
TS-873A, 8x Exos 8TB Raid5 for Backup
Re: HBS 3 does not start (app remains dark)
Please open a ticket with Qnap support.
Thanks P3R,
in the end your advice helped to solve problem, although in a very unexpected way:
- as part of the ticket opening, it is required to attach diagnostic protocols. I tried that, but a chrome browser extension somehow interfered with the protocols download, so I opened the QTS config page in Internet explorer to download that protocol.
That brought me to the idea to open HBS3 in the internet explorer session... et voila, HBS3 worked fine (after clicking away a window praising the features of the new HBS3)
And after that, even in Chrome HBS3 worked fine! (without displaying that feature window).
So my current conclusion is
- the feature window somehow interfered with Chrome
- always ask for support, it helps even if it doesnt help
best regards
Rainer
best regards
Rainer
mariachi76 wrote: ↑Mon Jul 13, 2020 7:56 pm - always ask for support, it helps even if it doesnt help
