HBS 3 ver 14.0.1215 gets bogged down at 5%
Backup, Restore, Netbak Replicator, Cloud Storage Services
alokeprasad
Easy as a breeze
Post by alokeprasad »
This is a BU of the NAS to an external USB3.1 drive. The drive has been checked by WD utilities (full surface scan) and shows no SMART errors. The USB drive is freshly NTFS formatted in QTS.
Version control is on, QuDedup is off.
After about 5 minutes, the job gets really slow (and keeps getting slower).
Here are some screenshots showing the progress and the job settings. Smart versioning is enabled.
Any idea whats going on?
NAS: TS-453Be
RAM:Crucial 8GB Kit (2 x 4GB) DDR3L-1600 SODIMM CT2KIT51264BF160B
QTS: 5.1.4
HDD's: RAID 6: Four 8TB WD Red (WD80EFAX)
USB HDD: One 12 TB WD Elements (WDBWLG0120HBK-NESN)
Switch: Netgear GS108
alokeprasad
Easy as a breeze
Re: HBS 3 ver 14.0.1215 gets bogged down at 5%
Its been running all day, and this is the best it can do.. :( :(
NAS: TS-453Be
QTS: 5.1.4
WarmHeart
Post by WarmHeart »
I have the exact same problem. Stuck at 5%. BU to ext. drive (8tb EasyStore) via USB 3.1.
First I tried BU and it kept stopping arbitrarily. Then I created a "sync" and now it's stuck at 5% for the past 24 hours. With Sync I can look at which files have been copied -- and, yes, only about 5% have been and nothing more. I've stopped and restarted it, and it copied a few more but is stopped again.
Something is seriously wrong with this version of HBS 3 backing to external drives. My other cloud backups are still operating fine.
Also look the Remaining Files size below! I don't have 129 TB! I think this is supposed to be 1.29TB !!
2021-02-03 10_56_23-zombie and 5 more pages - Personal - Microsoft​ Edge.png
UPDATE: While searching this forum it seems we're not the only ones. A similar thread: viewtopic.php?f=15&t=158854
QNAP TVS-471 w/ 4x4TB WD Reds (RAID1) + SSD (1 TB), 2 Storage Pools (8 TB, 1 TB), FW: QTS 4.5 (Latest...)
ColHut
Know my way around
Post by ColHut »
I’m ignorant but it it is not to do with too small a log file is it? Could set it to 1024 instead of the default 10.
Regards
alokeprasad
Easy as a breeze
Where do you set the log file size for HBS?
I have never changed that and BU's used to work. This must have been introduced in the recent HBS version update.
NAS: TS-453Be
QTS: 5.1.4
alokeprasad
Easy as a breeze
I checked the other thread. No one has any solutions besides abandoning HBS!
Their descriptions read just like mine. The BU slowing to a virtual stop at 5% in every case is a giveaway. Also, not all such BU's are to USB drives. So, it is some basic bug with HBS...
NAS: TS-453Be
QTS: 5.1.4
Ron1963
Been there, done that
Post by Ron1963 »
Several fixes in new HBS version 15.0.0128, like the not changing 5%.
1x TS251, 1x TS251D, 1x TS253
alokeprasad
Easy as a breeze
Yay! A new firmware update is out as well.
HBS 3 Hybrid Backup Sync 15.0.0128 ( 2021/02/03 )
[Fixed Issues]
- When executing an RTRR sync job, the displayed status would stop at “Syncing…5%” and then jump directly to “Success”.
- One-way sync jobs to OneDrive for Business would fail if the filename and file path were too long.
- Could not create an rsync job from Synology Hyper Backup to a QNAP encrypted shared folder through the rsync server in HBS 3.
- After updating HBS 3 on certain NAS models, one-way sync job reports would fail to provide certain information.
- The total capacity of a connected Google education account would not display as unlimited.
- One-way sync jobs to HiDrive would finish with an error if the total file size was over 2GB.
- On certain NAS models, HBS 3 would take too long to stop when the NAS was preparing for a system reboot.
- After creating and successfully running a QuDedup-enabled backup job to a Google cloud service, if you deleted some files from the source and ran the backup job again, the job would fail but the system log would indicate that the user had stopped the job.
- After successfully running an rsync job from Ubuntu to a NAS via the Ubuntu command line, and then restarting the NAS, running the job again via the Ubuntu command line would fail with an authentication error.
- When creating a backup job to a Google Cloud Storage space, selecting an existing bucket would return a file error.
- Fixed some minor bugs.
NAS: TS-453Be
QTS: 5.1.4
alokeprasad
Easy as a breeze
Sad to say, but the new HBS v 15.0.0128 is worse off. It is truly stuck (not even sloooowly transferring files like the previous version) :roll: :roll:
NAS: TS-453Be
QTS: 5.1.4
alokeprasad
Easy as a breeze
This is nuts!
I don't have a good backup of my NAS data in a month.
22 hours and HBS hasn't even finished estimating the size of the Backup!
NAS: TS-453Be
QTS: 5.1.4
ColHut
Know my way around
Post by ColHut »
Setting as in here
https://www.qnap.com/en/how-to/tutorial ... ackup-sync
The suggestion came from the end of here:
viewtopic.php?f=15&t=158671&p=778779&hilit=1024#p778779
Good luck.
alokeprasad
Easy as a breeze
Increasing the log file size 1024 MB did not work. The job still got stuck at 5%.
I split up the job into multiple pieces. The backup of the Multimedia directory (on the NAS) that has many small files, completed.
NAS: TS-453Be
QTS: 5.1.4
philipellis
Post by philipellis »
I've also found that small files are OK, but when it tries a 90MB file it just loops round endlessly.
The sync gets so far and then just starts again. Sometimes it gets 30% of the way through, sometimes 60%, sometimes other percentages, but never 100%.
I don't have this problem with either Dropbox or GoogleDrive sync.
I never had a problem with the old CloudDriveSync and I'd like to give that another go, but as it's obsolete I can't find a qpkg file, unless someone has one that they'd like to donate :)
I think the last version was 2.1.440
WarmHeart
Post by WarmHeart »
Yes, it appears the only viable short-term solution is to abandon HBS.
There are many other apps in the altapp store. Which one is closest to HBS in functionality?
Thoughts?
mroy5150
Post by mroy5150 »
I am having the same problem but with only one file on a Backup Sync to OneDrive. The backup syncs for all of my other folders (Documents, Pictures, Home Movies) work fine. However I've noticed that the backup sync for my Outlook PST file hangs at 5%. I've done some testing and determined that it seems to have a problem with larger files. My PST file is about 1.3 GB. I tried the same example with movies that are over 2 GB and get the same result. It doesn't error out it just hangs at 5% for as long as you let it go. This just started happening about a week ago. I'm not sure if there was a recent update to HBS that caused this to happen or if my outlook file just grew to a size that hit the limit. Either way if anyone can suggest an alternative I'd appreciate it. I used to use Cloud Drive Sync but it looks like it's no longer compatible with the recent versions of QTS.
TS-451+
8 GB RAM
2 WDRed 2TB Drives in RAID 1
Return to “Backup & Restore”
